Hi, Actually I just included this feature to create quick videoclips from an audio track for YouTube. It is not particularily efficient unlike the choices below, it just creates a compatible h264 video file with original audio.
You can do it on the "Stream multiplex" tab by following these steps:
1. Add an image file to the file list, and then double-clilck on it so it is added it to the tracks lists.
2. Right-click on the added video track and select "Use as still image for audio"
3. Add an audio file and add it to the tracks lists too.
4. Click on the Mux button and you are done.
You can also use an existing video as image source, and one frame will be extracted and used as image automatically, following the same steps
By default, the extracted frame used is the first one, using pre-input seeking on the Main tab you can choose when to extract such image frame.
Cheers
Results 61 to 90 of 830
New version 1.5
Changelog:
- Latest april 2018 ffmpeg zeranoe static builds included.
- New buttons to backup and restore presets and several configurations.
- Fixed bug with total list duration longer than 24 hours.
- Fixed error closing waveform window.
- File info now better displayed.
- Redesigned installer:
- Licensing info included.
- Now executable is always upgraded as expected.
- Installer will not overwrite existing presets from this version on. (But not for previous versions, you can still find it at %appdata%\FFBatch\ff_batch.txt)
- Minor interface changes
FFmpeg Batch Converter 1.5 x86
FFmpeg Batch Converter 1.5 x64
FFmpeg Batch Converter 1.5 Portable x86
FFmpeg Batch Converter 1.5 Portable x64
If you see a Windows Smartscreen warning, just click on more info and select "Run anyway".
[Attachment 45509 - Click to enlarge]Last edited by Eibol; 3rd May 2018 at 14:31. Reason: Typo / Addition
Hello, can your program accept an http m3u8 link as the source? eg: http://myserver.com/video.m3u8
m3u8 is a (HLS) playlist (UTF-8 encoded text file), should be possible to grab with a command like:
I'm experimenting with an implementation of this in FFQueueCode:ffmpeg -i "http://domain.com/file.m3u8" -c:v copy -c:a copy file.mp4
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
Great, if you can provide an online example I could look into it.
It was not a suggestion, just a fact. You can find online examples that provides links to m3u8 playlists. I have done a bit of testing back and fourth, and found that this command will grab 20 seconds of a blender movie from a m3u8 playlist:
Be aware that ffmpeg (at least on Linux, dunno bout Windoze) will be unresponsive for some time before the process starts. Good luck, m8!Code:ffmpeg -i "https://bitdash-a.akamaihd.net/content/sintel/hls/playlist.m3u8" -bsf:a aac_adtstoasc -c:v copy -c:a copy -t 20.0 out.mp4
I tried myself and could see how it works, thanks for the example.
If ffmpeg supports m3u8, knowing the required parameters it would be easy to implement a batch m3u8 capture feature.
I'm releasing an update in the next days, but for the next release I will see to include it for sure. -
New version 1.5.2:
Changelog:
- Redesigned file adding operation, now much faster, with progress info, and it can be cancelled. Thousands of files now can now be added trouble-free, no slowing down or freezing/runtime errors.
- Hidden files are ignored and errors accessing folders are addressed.
- New refresh list button.
- New renaming output field.
- Possible overwriting avoided when added multiple folders to single output folder.
- Added navigation buttons for multimedia file information.
- Minor interface redesign.
- Shortcut added to Sendto menu.
FFmpeg Batch
FFmpeg Batch (64 bits)
FFmpeg Batch Portable
FFmpeg Batch Portable (64 bits)
https://sourceforge.net/projects/ffmpeg-batch
[Attachment 45509 - Click to enlarge][/QUOTE] -
I'm working on a new M3U capture tab, I hope to have a beta working soon.
https://www.youtube.com/watch?v=PjVjjO8q3tM
Hi Eibol, will your program be able to accept live continuous streaming m3u8 files? or is this only a one time ts file downloader of what is currently in the m3u8 then stops?
I hope it will support any kind of m3u8 url, to be saved as mp4 o mkv. The point is that streamings have no specified duration, so I'm still trying to find a way to close gracefully an ffmpeg background process, so I don't have to show an external window, o kill the ffmpeg process resulting in a truncated file.
I'm still in early stages of understanding m3u8 urls.
Hi, thanks for the input, the program is fine but I think I used a 7-zip 64 bits installer. I will fix it soon.
Remember that you need Windows 7 with Service Pack 1 installed.
If you install 7-zip 32 bits you can decompress the .exe file to any folder and run it for sure.
https://www.7-zip.org/download.html
You may also need the .net framework in case it is not installed on your computer. Remember that you need Windows 7 with Service Pack 1 installed.
https://www.microsoft.com/en-US/download/details.aspx?id=53344
Fixed 32 bits portable version mismatch.
FFmpeg Batch Portable 1.5.2 x86 -
New version 1.5.3:
Changelog:
M3u8
- Added basic support for M3u8 links batch processing.
- Streaming m3u8 links supported (listed as infinite duration).
- M3u8 streams information button.
- Output to mp4/mkv or rtp/rtsp.
- M3u8 links are considered down if there is no response within 10 seconds.
Other:
- Batch subtitling will guess subtitles encoding, and allow to convert to utf-8 for non-english languages.
- Format field can be left blank so source file extension is used instead.
- Queue abortion will close processes gracefully at any time, to avoid truncated files.
FFmpeg Batch 1.5.3
FFmpeg Batch 1.5.3 (64 bits)
FFmpeg Batch 1.5.3 Portable
FFmpeg Batch 1.5.3 Portable (64 bits)
https://sourceforge.net/projects/ffmpeg-batch -
Hi!
great tool and thanks for your work!
Question: How is it possible to insert a watermark (png or jpg) into a batch of videos?
A simple comand to convert is f.e.: ffmpeg -i inputvideo.mp4 -i watermark.png -filter_complex "overlay=main_w-overlay_w-0:0" -codec:a copy outputvideo.mp4
May be somebody can help.
Regards
henry -
Ho, I think you could achieve it with Ffmpeg Batch using something like this on the parameters field:
(File output will be obtained from source file).Code:-i "C:\Users\Abel\Pictures\Iconos\overlay.png" -filter_complex "overlay=main_w-overlay_w-0:0" -c:v libx264 -crf 20 -preset veryfast -c:a copy
A couple of things:
- The video needs to be re-encoded, so -crf 20 is good quality, but it will take some time depending on files duration.
- For some reason the first video will be processed twice, the parameters field is not expecting an additional input. The rest of the batch processing should be fine,
I hope you make it work.
Hi Eibol,
Thanks for an excellent conversion tool! It works like a charm.
Any plans from converting aax to mp3 in the works?
I've used another tool that's available, but it doesn't work.
Also, is M3U8 to download from where, specifically?
Again thank you!
gothicus -
Hi,
I've been checking about aax files, they are supported but they require some "activation bytes" prior to any conversion. If you already have those bytes you can add on pre-input field the parameterObtainint those bytes is beyond this ffmpeg gui. This url may help you: https://wphelp365.com/blog/ultimate-guide-downloading-converting-aax-mp3Code:-activation_bytes [your_activation_bytes]
New version 1.5.4.
- M3u8 improvements:
- More realiable URL validation.
- Now all M3u8 urls can be processed at once, and any of them cancelled at any time.
- Multiple url processing shows individual and total progress information (for fixed duration urls).
- Automatic shutdown available after m3u8 url processing.
- General:
- Minor improvements and bugfixes
FFmpeg Batch 1.5.4
FFmpeg Batch 1.5.4 (64 bits)
FFmpeg Batch 1.5.4 Portable
FFmpeg Batch 1.5.4 Portable (64 bits)
Hi,
Thanks for a great software.
How do you load a DVD or Blu-ray in FFmpeg Batch so to copy Blu-ray m2ts to mp4 and convert DVD to mkv ?
Thank you.
Batch trim using FFMPEG
By taonas in forum EditingReplies: 4Last Post: 25th Feb 2021, 10:17 -
(HELP PLEASE) FFmpeg - Batch Remove metadata
By uppon2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jun 2016, 06:47 -
Batch stabilize script for ffmpeg
By racer-x in forum Video ConversionReplies: 20Last Post: 2nd Jun 2016, 17:10 -
FFMPEG Batch Converter! Help Please
By kerafb in forum Video ConversionReplies: 0Last Post: 15th Jan 2016, 19:18 -
Can I get a little help with an ffmpeg script/batch file?
By Iced Coffee in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2015, 01:56
