Version 1.3.3
- Final interface layout.
- Automatic shutdown also available once processing started.
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.3_x64.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.3_x86.msi
Results 31 to 60 of 830
Nice tools, Thank you.
is there no option just to extract video / audio without convert? -
Version 1.3.5
- New checkbox so you can keep source path folder structure on output destination.
- Now conversion can be started pressing enter on preset of parameters field.
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.5_x64.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.5_x86.msi -
When I try to convert MP4 h264 4k video to DNxHR (any profile), the program crashes, then ffmpeg in the background starts as soon as I reopen the program and I get a video with some artifacts.
Video is from a GH5 https://drive.google.com/file/d/1q9MkWhjqJZU5VS_uZYHOEwyPK4e1sK-6/view?usp=sharing
Parameters needed and used:
-c:v dnxhd -profile:v dnxhr_sq -c:a pcm_s16le
As you can try, you can see that try preset says that everything is fine, sad thing is that when you click start the program freezes and crashes. -
Hello,
Thanks for the input. I downloaded and tried converting the file with your parameters and got that weird error.
I guess that you are using mov as output in format field.
I tried this alternative and it worked: -c:v dnxhd -profile:v dnxhr_sq -c:a copy
I'm not sure why this happens, but since the audio is already pcm 16 bits, the audio conversion is not necessary.
I hope this helps.
Version 1.3.6
- Slight interface fix.
- Latest ffmpeg builds included.
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.6_x64.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.6_x86.msi
https://sourceforge.net/projects/ffmpeg-batch/ -
Do I have to uninstall first or I can go straight and install the new version?
In fact it did not update, but uninstall and reinstall was just fine.
One more thing, I'm used to convert with the Fraunhofer AAC, how can I configure it inside FFmpeg Batch? -
The Fraunhofer aac encoder license does not allow to distribute it compiled in your software, but you can compile it yourself and replace the ffmpeg version on the installation folder (Program Files\Eibolsoft\FFmpeg Batch).
I have a pre-compiled 64 bits ffmpeg version with libfdka_aac included, you can try it: https://files.videohelp.com/u/273695/ffmpeg_libfdka_aac.zip -
Wokring perfectly, so if there will be updates on FFmpeg Batch I'll need somewhere to get the ffmpeg with the Fraunhofer AAC enabled right?
So I found a little bug, when I add a second preset, then delete the one before the first preset that I created, the latter will include in the title the name and parameters form the last one... I don't know if it makes sense what I just said, but here it is the ff_batch.txt file (the one in the roaming folder):
BeforeAfterCode:-c:v copy -c:a aac -cutoff 20K -b:a 256K -ac 2 mkv yes Vs PR: Video: MP4 Stream copy & -c copy % mp4 PR: Video: Convert audio track to AAC HQ 2 channels & -c:v copy -c:a aac -cutoff 20K -b:a 256K -ac 2 % mkv PR: Video: Convert audio track to AC3 2 channels & -c:v copy -c:a ac3 -b:a 256K -ac 2 % mp4 PR: Video: Convert to H264 HQ + Source Audio & -c:v libx264 -crf 20 -c:a copy % mkv PR: Video: Convert to H264 Ultrafast + Source Audio & -c:v libx264 -crf 23 -c:a copy % mkv PR: Video: Convert to H265 HQ + Source Audio & -c:v libx265 -crf 23 -c:a copy % mkv PR: Video: Resize 1280x720 H264-AAC & -c:v libx264 -crf 23 -vf scale=1280:720 -c:a aac -b:a 128K % mp4 PR: Audio: Convert to FLAC 16/44,1KHz 2 channels & -vn -c:a flac -ar 44100 -sample_fmt s16 -ac 2 % flac PR: Audio: Convert to MP3 VBR HQ 2 ch embedded cover & -c:v copy -c:a libmp3lame -qscale:a 0 -ac 2 % mp3 PR: Audio: Convert to MP3 VBR HQ 2 ch & -vn -c:a libmp3lame -qscale:a 1 -ac 2 % mp3 PR: Audio: Convert to MP3 CBR HQ 2 ch & -vn -c:a libmp3lame -b:a 224K -ac 2 % mp3 PR: Audio: Convert to WAV 16/44,1KHz 2 channels & -vn -c:a pcm_s16le -ar 44100 -sample_fmt s16 -ac 2 % wav PR: Subtitle: Extract first subtitle track to SRT & -map 0:2 -c:s copy % srt PR: x264, CRF 20, YouTube FPS 30, FAAC, Full & -c:v libx264 -crf 20 -keyint_min 15 -bf 2 -tune film -profile:v high -pix_fmt yuvj420p -c:a libfdk_aac -cutoff 20K -b:a 320k % mp4
Code:-c:v copy -c:a aac -cutoff 20K -b:a 256K -ac 2 mkv yes Vs PR: Video: MP4 Stream copy & -c copy % mp4 PR: Video: Convert audio track to AAC HQ 2 channels & -c:v copy -c:a aac -cutoff 20K -b:a 256K -ac 2 % mkv PR: Video: Convert audio track to AC3 2 channels & -c:v copy -c:a ac3 -b:a 256K -ac 2 % mp4 PR: Video: Convert to H264 HQ + Source Audio & -c:v libx264 -crf 20 -c:a copy % mkv PR: Video: Convert to H264 Ultrafast + Source Audio & -c:v libx264 -crf 23 -c:a copy % mkv PR: Video: Convert to H265 HQ + Source Audio & -c:v libx265 -crf 23 -c:a copy % mkv PR: Video: Resize 1280x720 H264-AAC & -c:v libx264 -crf 23 -vf scale=1280:720 -c:a aac -b:a 128K % mp4 PR: Audio: Convert to FLAC 16/44,1KHz 2 channels & -vn -c:a flac -ar 44100 -sample_fmt s16 -ac 2 % flac PR: Audio: Convert to MP3 VBR HQ 2 ch embedded cover & -c:v copy -c:a libmp3lame -qscale:a 0 -ac 2 % mp3 PR: Audio: Convert to MP3 VBR HQ 2 ch & -vn -c:a libmp3lame -qscale:a 1 -ac 2 % mp3 PR: Audio: Convert to MP3 CBR HQ 2 ch & -vn -c:a libmp3lame -b:a 224K -ac 2 % mp3 PR: Audio: Convert to WAV 16/44,1KHz 2 channels & -vn -c:a pcm_s16le -ar 44100 -sample_fmt s16 -ac 2 % wav PR: x264, CRF 20, YouTube FPS 30, FAAC, Full & -c:v libx264 -crf 20 -keyint_min 15 -bf 2 -tune film -profile:v high -pix_fmt yuvj420p -c:a libfdk_aac -cutoff 20K -b:a 320k % mp4PR: x264, CRF 20, YouTube FPS 30, FAAC, Limited & -c:v libx264 -crf 20 -keyint_min 15 -bf 2 -tune film -profile:v high -pix_fmt yuv420p -c:a libfdk_aac -cutoff 20K -b:a 320k % mp4
Yes, I think you found an issue when saving presets. I thought it was solved, it is related to blank lines not being properly detected when deleting a preset.
I'm afraid this will need some redesign. For the moment, you should try saving presets with names that do not start with the same text, lilke this for example:
1. (Name)
2. (Name)
3. (Name)
The corrected config txt file:
mkv
yes
Vs
PR: 1. x264, CRF 20, YouTube FPS 30, FAAC, Full & -c:v libx264 -crf 20 -keyint_min 15 -bf 2 -tune film -profile:v high -pix_fmt yuvj420p -c:a libfdk_aac -cutoff 20K -b:a 320k % mp4
PR: 2. x264, CRF 20, YouTube FPS 30, FAAC, Limited & -c:v libx264 -crf 20 -keyint_min 15 -bf 2 -tune film -profile:v high -pix_fmt yuv420p -c:a -cutoff 20K -b:a 320k % mp4
Thanks for the input and sorry for the inconvenience.
Glad to know you can use the config file at your will.
I think I could fix the issue deleting presets, I've done some tests and it did not show up.
Please uninstall previous version so executable is properly updated.
Now in .zip format, for some reason, scanning with Virus Total, only the 32 bits version shows a malware warning by Baidu, rest of 60 scan engines show file is safe.
Version 1.3.7.
- Fixed config file corruption deleting presets.
- Fixed Baidu antivirus detecting the installer as false positive malware.
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.7_x64.zip
https://files.videohelp.com/u/273695/FFbatch_setup_1.3.7_x86.zip
https://sourceforge.net/projects/ffmpeg-batch/Last edited by Eibol; 5th Mar 2018 at 09:40. Reason: More info, added links, malware false positive
New version 1.4
- Added one-click screen recording button using gdigrab. Added some screen recording presets.
- Slight interface change for ffmpeg output and Windows 10.
https://sourceforge.net/projects/ffmpeg-batch -
New version 1.4.1
- 1-click screen capture now validates preset before starting countdown.
- Faster preset validation, now processing starts faster.
- Slight interface change.
Please uninstall previous versions before installing.
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.1_x64.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.1_x86.msi -
New version 1.4.3
- Added support for .ASS subtitles.
- Burn subtitles batch feature added.
- Added checkbox to rename output files automatically.
Please uninstall previous versions before installing new one.
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.3_x64.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.3_x86.msiLast edited by Eibol; 12th Apr 2018 at 10:52. Reason: ASS subtitles
Hi,
I have developed this beta 1.4.4 version, so the application can be run with no installation required, provided .NET libraries are already installed.
Just decompress the files on any folder and run FFbatch.exe. It will show just the default and one sample preset created.
https://files.videohelp.com/u/273695/FFBatch_1.4.4_portable.zip
New version 1.4.5.
- Standalone self-extracting portable version available.
- Enhanced trim feature.
- Volume changed to dB.
- New reset to default presets and settings button.
- Minor interface changes.
Installer:
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.5_x86.msi
https://files.videohelp.com/u/273695/FFbatch_setup_1.4.5_x64.msi
Portable:
https://files.videohelp.com/u/273695/FFmpeg_Batch_1.4.5_Portable_x86.exe
https://files.videohelp.com/u/273695/FFmpeg_Batch_1.4.5_Portable_x64.exe
Please uninstall previous version before updating. I will have fixed this upgrading issue on future releases.
If you want to keep your custom presets before uninstalling, save ff_batch.txt located at %appdata%\FFbatch
and then replace it back there in that folder.Last edited by Eibol; 25th Apr 2018 at 05:06. Reason: Issues upgrading / keeping your ffmpeg presets
Very nice work! Thanks for this wonderful software.
How do you create a video from a still image and an audio file? -
Mr_Anderson ... (Agent Smith here)
If you want to make e.g. a menu with audio or an intermission screen in a consumer format which requires specific authoring (DVD Video, Blu-ray): Don't make a video, they support one still frame with underlying music.
But if you are sure you need it: guide video on YouTube with ffmpeg command line parameters (example below). How to apply those in this GUI, is a different topic...
Basic idea: Loop the image infinitely, and cut the loop at the duration of the (shorter, because finite) audio track. Well, I guess a more usual frame rate is advisable...Code:ffmpeg -y -loop 1 -r 1 -i image.png -acodec copy -i audio.mp3 -shortest thisvid.mp4
Batch trim using FFMPEG
By taonas in forum EditingReplies: 4Last Post: 25th Feb 2021, 10:17 -
(HELP PLEASE) FFmpeg - Batch Remove metadata
By uppon2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jun 2016, 06:47 -
Batch stabilize script for ffmpeg
By racer-x in forum Video ConversionReplies: 20Last Post: 2nd Jun 2016, 17:10 -
FFMPEG Batch Converter! Help Please
By kerafb in forum Video ConversionReplies: 0Last Post: 15th Jan 2016, 19:18 -
Can I get a little help with an ffmpeg script/batch file?
By Iced Coffee in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2015, 01:56
