Hi Eibol
Thanks for your program. I love it. I had been using FFMPEG from the command line for years because I like having finer grained control. (Plus, it's easier for me to screw up an encoding that way) But, your program's profiles make things so much easier than having to remember different command line entries for different tasks.
I have a couple of feature requests (or maybe I am overlooking something). Would it be possible to retain the addition and placement of custom columns across sessions? It's not a big deal to add them when the program is started, but it seems that they need to be added before loading videos into the processing list. For me, anyway, if I forget and load up some videos first, the GUI will hang if I add the custom columns *after* loading videos.
Also, while the "Remember window position" setting works, can you add "Remember window size", (or just "Remember window position and size", too?
Again, neither is a big deal, just something I find myself doing repeatedly every time I open the program.
Thanks!
Results 511 to 540 of 830
I know it's a late reply, but, in addition to regressing to the older versions of FFMPEG, you can always compile your own binaries if the ones that Eibol includes (I believe these have been Gyan's full builds since Zeranoe stopped releasing build) do not have the functionality you seek. The media-autobuild_suite from RiCON makes compiling your own trivial under Windows and you can include, --enable, and --extra anything and everything under the sun. Just download the build script from here https://gitlab.com/RiCON/media-autobuild_suite and run it. It will prompt you step-by-step of what you wish to include or not and build the binaries for you.
Hello and thank you Eibol for your software, it is really great.
I have a suggestion for a future version, is it possible to add the possibility to execute a command line at the end of the execution of a file in the batch processing.
I would like to be able to run this command after each file processed: mkvpropedit.exe file.mkv -- xxxxxxxxxxxxx. -
My laptop has amd radeon in it and i use to use gpu decode amd witch is vce name but i noticed latest version its not listed anymore anymore as gpu decode. It use to be listed not sure what version it was listed last. Was it removed from ffmpeg batch. If it was how come?
Thank you Eibol for considering my request
I use this command because FFmpeg after transcoding does not update the video bitrate in mediainfo.
mkvpropedit" xxx.mkv --add-track-statistics-tags
Hi Eibol,
thanks for your batch program - works like a charm. I do have a feature request though.
Is it possible to integrate the deinterlace function? (yadif)
It would be very useful for older video material.
Michael -
Hi, thanks for the suggestion, I don't know much about deinterlacing, but I guess you can play with it just adding
to your parameters, or check documentation if default filter values are not good for your purposes.Code:-vf yadif
https://ffmpeg.org/ffmpeg-filters.html#yadif-1
There are three parameters, they can be use like -vf yadif="0:0:0" -
@Eibol,
In the portable version (2.3.7), I encounter this error/warning when I try to do the sleep prevention setting.
[Attachment 58475 - Click to enlarge]
[Attachment 58476 - Click to enlarge]
Any idea why this happens? -
Hi JKyle, thanks for the report, it's a bug of my latest portable reconfiguration. It'll be fixed for next release.
You can use this patched exe to test it.
Ooops, I found another wrong path. I hope this patched executable finally fixed it.
After reading the latest reviews, just a reminder that in latest 2.3.7, Portable version issues have been addressed, now settings are no longer saved on appdata folder.
On next release one remaining bug on portable version is solved, and some other features I'm working on will be available, like:
- Overall encoding speed and fps displayed during sequential and multi-file encoding (good for performance comparison).
- Average speed/fps displayed after queue encoding and saved to log.
- New feature to run command on each successfuly encoded output file.
- Custom columns layout saved and reloaded on startup.
Cheers -
Great, just right there
[Attachment 58639 - Click to enlarge]
When I use file list filtering with :
video codec - any stream - h264 (or other) - keep
the filtering works fine, but if I use :
audio codec - any stream - eac3 (or other) - keep
the filtering doesn't work -
Right, thanks, I found the issue. It is solved in this executable.
Should punctuation stop subtitle burn in?
example
Y:\New to Process\Movie's (2021)\Movie's (2021).srt
Removing apostrophe from folder and file naming allowed conversion. -
how can we set limit-tu? i getting error if i add following command for x265
some x265 command i found hereCode:-limit-tu 4
Code:https://x265.readthedocs.io/en/master/presets.html
Because that is not a native FFMPEG option, but rather a libx265 one, you must pass it specifically to x265.
BTW, if you change "limit-tu" to any non-zero value, your must also set "tu-inter-depth" greater than 1, or "limit-tu" will revert back to the default 0 with just a warning and proceed, i.e., your encoding will complete without error, but with "limit-tu=0".Code:-c:v libx265 -x265-params "limit-tu=4:tu-inter-depth=4"
Bug report (maybe)...
Currently using v2.3.2 Portable, so pls correct me if v.2.3.7 has fixed this.
Upon completion of an encoding queue and with 'delete files when finished' checked, sometimes there is a pop-up stating some files could not be deleted.
However said files are in the recycle bin, not in source lfolder!
Thanx.Last edited by Frasier; 12th May 2021 at 00:59.
Settings files - Updating from v232 to v238 Portable?
For v232 - I found the settings .ini files in C:\Users\"user"\AppData\Roaming
For v238 - I see there is an empy 'settings' folder made under the portable location folder.
How do we copy / transfer our presets and settings?
- simply copy > paste or... ?? -
Re. New Feature in v238: - New feature to run command on each successfuly encoded output file
What is the syntac for the Arguments?
- are any quotes (") needed around them or...?
eg. if I want to run ffmpeg.exe with arguments -c:v copy -c:a ac3 -b:a 96K -ar 44.1K
- this results in an error, so do I need quotes around them or... ? -
how can we burn .ass subtitle manually. i tried this but getting error
Code:-c:v libx264 -crf 20 -c:a copy -vf "ass=D\:\\Download\\aa.ass"
Batch trim using FFMPEG
By taonas in forum EditingReplies: 4Last Post: 25th Feb 2021, 10:17 -
(HELP PLEASE) FFmpeg - Batch Remove metadata
By uppon2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jun 2016, 06:47 -
Batch stabilize script for ffmpeg
By racer-x in forum Video ConversionReplies: 20Last Post: 2nd Jun 2016, 17:10 -
FFMPEG Batch Converter! Help Please
By kerafb in forum Video ConversionReplies: 0Last Post: 15th Jan 2016, 19:18 -
Can I get a little help with an ffmpeg script/batch file?
By Iced Coffee in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2015, 01:56
