Hello, dear all.
If I have several files on a PC and I do not want to open all of them and printing one by one, how to proceed?
For images files ( eg: jpg, bmp, png, etc) I can use Irfanview.
Using such program I can use the option Thumbnails and select several files for printing in a single action.
Maybe other image viewers like ACDSee or XnView can do similar things too. I do not have tried any of them yet.
But if I have other files like txt, doc, xls, pdf, rtf, ppt, how to do it properly for such extensions?
Do you know any programs that can make such task easy and direct? Freewares and portables programs are preferred if it's possible.
Thanks for your tips!
Best regards.
devil ( johner)
Open printer in control panel. Show print properties window. In Print menu, pause printer. Drag and drop whatever files you want to print; they will be added to the queue. Review your queue. Make sure printer is ready. Un-pause it and stand back...
Hello, dear all.
@ jagabo & raffriff42: Thanks for your help!
Hi. Can I do such action no matter my OS version? I mean, my OS is Windows 7, but this tip work in all Windows versions, including Windows 10?For many of them you can highlight the file(s), right mouse click on one, select Print from the context menu.
Thanks again for your advices!
PS: do you know any program that can do such printing job ( for several types of files ) in batch mode?
Best regards.
devil ( johner) -
What do you mean by batch printing? Windows maintains a queue of print jobs so you don't explicitly need to batch process. Using the method I gave earlier lets you send many files to the queue at the same time (rubber band highlight all the files, then right click on one, select Print) . If you you mean you want to send a bunch of files to the queue via a batch file you can use the PRINT command.
Video batch files.
By pcspeak in forum Video ConversionReplies: 62Last Post: 14th Feb 2018, 20:24 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 14:40 -
Need help converting batch video files!
By tcarp in forum Video ConversionReplies: 3Last Post: 13th Mar 2014, 08:10 -
Help in printing Video Files and their Attributes to text or excel
By jcikal in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2013, 00:41 -
Batch processing all my video files.
By Paxmilitaris in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2013, 16:43
