I've tried using the multi-region hack for the Samsung DVD-511 a few times and each time I've tried it I keep getting the same result, when I'm supposed to press repeat and enter the code for my player I don't get the "Region Code" menu like I'm supposed to, I've tried this several times, each time doing a cold start, can someone help me figure out why the code doesn't work. is it defunct? Or am I doing something wrong. I'm using this method:
http://www.vcdhelp.com/dvdplayershack.php?select=Samsung%20DVD%20511
is something supposed to happen when I press repeat? because when I'm entering the code the numbers appear in the corner, and afterwards nothing happens. thanks for your help.
Results 1 to 11 of 11
I'm not totally sure about this, but are you sure you're pressing the 'repeat' key and not the 'repeat a-b ' key? I seem to remeber an issue with that happening.
If I'm talking out of my arse, re-post your question on www.709online.com , cos they know what they're talking about when it comes to Samsung DVD players... -
Originally Posted by Jayce72
Well I went to the URL you supplied and found another site and I don't think my player is hackable without doing a bios revision on it. unfortunately I'llhave to probably find another player (it doesn't matter since I was trying this on my dad's player anyway. My original player is one of those First Generation Philips Maganavox player that can't be hacked unless I have a PalmV unfortunately that's not an option for me either. Anywho thanks and if anyone knows how to hack a Philips Without the PalmV or modchipping LMK. later
What do you have to do with the Palm? If it's simply sending an IR code (like the Philips models), you could buy a One For All 6 (a lot cheaper) and program the function on.
Are you in the US? If so, the OFAs there don't have Magic buttons, they're called Set or Setup, but they do the same thing. If you can find an OFA remote that operates DVD, you'll be fine. Juts follow the instructions on the site and it'll be hacked.
However if you are in the US, you may not be able to watch PAL DVDs (ie Region 2) as your TV is more than likely NTSC-only compatible. Multi-standard TVs are quite common in Europe now, but less so in the US.
(that last bit was just in case, I don't want you wasting $30 and blamimg me -
Ah thanks that clears a lot up for me, (I'll give it a shot right now cause saw those and thought maybe that was the supposed "Magic" button since it was in the shape of a star. As for region 2 those are NTSC (at least last I checked allmy region 2 dvd's said NTSC on the back of their cases)
I don't know what sucks more, I feel like crying now, the damn remote doesn't work with my player. arrgh....
Hi again,
Well if you have Japanese Region 2 DVDs, I think those will be in NTSC. If you get them from Europe however, they'll be PAL.
Re the remote, does it have codes for any DVD Players at all? If so it should have code (0)573 listed, and that's the code for your Samsung. If not, does it operate Tuners? If so enter the code for an Aiwa Tuner, which should be (0)121. Then try pressing Magic (or whatever) once and releasing it, and then pressing 0-8-5 while pointing towards the DVD.
Good luck and let me know how you get on! -
Samsung DVD-P347 region 2 hack?
By pleasemakeitwork in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Jan 2011, 16:08 -
How to hack Samsung DVD-HR773 to region free ?
By Bud_Bud in forum Newbie / General discussionsReplies: 1Last Post: 16th Jun 2010, 04:10 -
Hack for Samsung DVD-1080P8 for region 1 ???
By juliette0406 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Jul 2008, 12:21 -
Samsung DVD-1080P7 Region Hack
By adrian4321 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Apr 2008, 23:23 -
NEED Region Free Hack for Samsung DVD R120
By arctul in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Dec 2007, 09:09
