Hello guys,
I need a simple tool to capture live streams (with audio) -- non command line utility, please.
Hi,
Please check if this link can be of any use: https://www.techsmith.com/blog/record-live-streaming-video/ -
Youtube-dl is a command line utility. But if you use the procedure described here you can use it without ever dealing with the command line:
https://forum.videohelp.com/threads/384888-how-can-i-make-drag-an-drop-batch-file-for-...86#post2495186
Live streams at youtube may never end so you have to terminate the batch file manually (close the window or type CTRL+C in it). That will leave ".part" at the end of the downloaded file. Just rename the file without the .part. For example, if you get Filename.mp4.part, rename it Filename.mp4.
how to record this live streaming
By bfa1trung in forum Video Streaming DownloadingReplies: 5Last Post: 13th Aug 2015, 17:32 -
Live Video Streaming. Different methods ?
By DB83 in forum Video Streaming DownloadingReplies: 5Last Post: 25th Apr 2015, 09:10 -
Streaming Live Video from my Camcorder
By ErikJG in forum Capturing and VCRReplies: 2Last Post: 21st Aug 2014, 08:49 -
Recording Live Video and Streaming on LAN!
By hasnainmj in forum Video Streaming DownloadingReplies: 0Last Post: 13th Jan 2014, 04:29 -
Can I play streaming video through this site through WD TV Live??
By RBCC in forum Video Streaming DownloadingReplies: 2Last Post: 26th Mar 2013, 17:56
