What is the best editor to edit dash cam footage. It would only be simple things like cutting/joining/ brightening/contrast and maybe adding text so don't want to go through vegas
The files produced are Audio Video Interleave
Here is a sample of the files produced
General
Complete name : C:\Users\sample.AVI
Format : AVI
File size : 277 MiB
Duration : 2 min 1 s
Overall bit rate : 19.2 Mb/s
Video
Format : JPEG
Codec ID : MJPG
Bit rate : 18.1 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.656
Stream size : 262 MiB (95%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 512 kb/s
Channel(s) : 1 channel
Sampling rate : 32.0 kHz
Bit depth : 16 bits
Stream size : 7.39 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 1000 ms (30.00 video frames)
Results 1 to 14 of 14
AVIDemux would be one possibility. Or if you need more features, VirtualDub FilterMod.
What formats would you want to convert them to? Not sure how either handle MJPG. -
Because it's a weird 32khz instead of a more standard 44.1khz(CD Audio) and 48khz(TV/DVD Audio). Seems like they did this as a way to cut down on the overall bitrate by sampling the mono audio less per second. As long as the decoder decodes it at the right sampling rate then there should be no real problem with playback or encoding it to something like MP3/AAC. But encoding it to a higher sampling rate might cause some slight losses as resampling is never perfect.
I am trialling wondershare video converter ultimate. I saw on another thread wondershare products are not recommended here. Why is that? Is there adware or spyware? I got no alerts
Good Software For Cropping Dashcam Video ???
By NewTwoVideo in forum EditingReplies: 3Last Post: 9th Oct 2017, 17:11 -
Need to pare down 20 hours of 1080p dashcam footage (130 GB) to a few mins
By blackmambo in forum Video ConversionReplies: 2Last Post: 21st Mar 2017, 02:28 -
All-in-one pacjage (if any) for editing dashcam videos
By indijay in forum EditingReplies: 1Last Post: 18th Nov 2016, 14:39 -
Dashcam (MOV) recovery
By JamesR in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2016, 05:54 -
how to fix an odd dashcam AVI in VirtualDub?
By vratislav in forum Video ConversionReplies: 10Last Post: 7th Jun 2016, 02:08
