Hi.
my friends lg tv bundled a hard disk with some uhd movies. this is a folder of big movie:
audio.mlkv video.mkv Big.dps subtitle_A.smi subtitle_B.smi
but vlc cannot play it correctly.
Is there any way to play It or remuex it?
Hi,
what does it mean correctly ? It plays the file and some part is missing, or it refuse all tracks?
Usually nowadays TV has function for PVR but recording can be played only at current tv.
You can try use Mkvtoolnix to get them together in one file. But if not playable in VLC i doubt about it. -
It is not directly related to this, but even if you buy same model of TV, there isn't guarantee that you will be able play these files. Some TVs or Set top boxes recorded videos can be played just in genuine TV STB that recorded video. Genuine I mean serial number of device. But since I don't search for it, I don't know if is this situation rare or almost in all cases. Therefore when I will buy STB with HEVC (DVB-T2) I will buy model, that supports editing recorded program in PC (not encrypted).
What I'm try to say is. Check if the recording of your device is encrypted. If so, you can keep recordings on HDD.The recordings becomes after 3-4 years (when TV gone) useless (in case you burned them, all dvd blu-ray media become garbage). HDD you can format and recording again with new TV. But of course your TV gone, recordings gone with it also.
BernixLast edited by Bernix; 28th Nov 2017 at 07:54.
UHD BD Specs
By SameSelf in forum Newbie / General discussionsReplies: 18Last Post: 4th Jan 2017, 15:59 -
Cutting MKV Files - Subtitle Files Inside of MKV
By devilcoelhodog in forum EditingReplies: 2Last Post: 11th Sep 2016, 21:29 -
Sony on UHD
By SameSelf in forum Latest Video NewsReplies: 1Last Post: 1st May 2016, 00:48 -
Which one of these containers would be best for UHD 4k? AVI, MKV, 3GP, FLV
By yeto in forum Newbie / General discussionsReplies: 9Last Post: 12th Aug 2015, 13:53 -
.img vs UHD?
By essjay in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2015, 15:26
