I have 2 questions concerning TMPGEnc Plus. The first is , when I convert both vcd discs to dvd mpeg2 standard everything goes fine without a hitch however, when I try to open the second file to merge it with the first file it tells me the second mpeg file is not compatible with the first file. I converted both using the same settings, I can not figure out why this is happening and this is happening quite often. Never had this problem with previous versions of TMPGEnc.I am using the new Plus version 2.53 and purchased it from TMPGEnc. Any help would be greatly appreciated.
The second question is on some of my movies when I convert the discs to mpeg2 dvd on the preview screen I will get a disk that freezes, the video doesn't move but the timer is still going. Is this due to bad frames in the original recording? and if so is, there a program that could fix this and then I could re-encode it again using TMPGEnc without any problems? Again any help would be greatly appreciated. Thanks!![]()
Results 1 to 1 of 1
Questions about interlacing/deinterlacing - TMPGenc users
By yukon33 in forum Newbie / General discussionsReplies: 9Last Post: 25th Jun 2010, 13:41 -
TMPGEnc DVD Author 2 questions
By siluet in forum Authoring (DVD)Replies: 15Last Post: 27th Apr 2009, 20:57 -
TMPGEnc DVD Author 3 (TDA) Questions
By Brent.M in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2008, 23:34 -
Some questions on TMPGEnc DVD Author 3
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2007, 06:32 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15
