Hey there!
I'm new to this and I was hoping someone could help me out. I have a DVD of a live concert and I wanted to rip the DVD to my hard drive, but I want ONLY the AUDIO. Does anyone know how to do this? Do I have to rip the whole DVD first and then extract the audio? Thanks ahead to anyone who can help!
I've tried DirectDVD, but for some reason, it only encodes as you watch the movie and then the files just diappears; I've also tried SmartRipper/Vob2audio as well, but for some reason, SmartRipper doesn't create the right files (audio stream) that Vob2audio needs to encode.
I'm primarily looking to encode several concerts into MP3 format from the new MY DYING BRIDE DVD. I NEED HELP!
thanks.
Use Smart Ripper, and change the settings to split by Chapter instead of VOB and then load each "Chapter" into DVD2AVI, and you can either create a WAV or a MP3 directly from it.
I Think (not sure) but you can use DVD2AVI to create the WAV/MP3 directly from the DVD using the OpenDVD.DLL plugin.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
CoolEdit Pro!
Best Regards,
Sefy Levy,
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 14:56 -
DVD Ripping and conveting to AVI question
By undyingforce in forum DVD RippingReplies: 4Last Post: 24th Apr 2010, 12:05 -
ripping a dvd to mkv h264 filesize question
By stackner in forum DVD RippingReplies: 5Last Post: 16th Jan 2009, 17:13 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 22:09 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
