My dad had our old 8mm films transferred to DVD, however some of the film is misaligned so that the bottom of the film is on top of the screen as if the film is cut in half and put in the wrong order.
I don't know exactly what to call that, so I'm having trouble even googling it. But the film looks vertically off-center.
Does anyone know of a Avisynth filter or other way to fix that? It would need to move the top of the frame to the bottom where it belongs. There's also some film jitter that might complicate things because it changes the position of the split.
Here is an ASCII illustration of the issue.
Code:|-----------------------| | Bottom of Film | |=======================| | | | | | | | Top of Film | | | | | | | |-----------------------|
	It's called framing error. It's not the same frame cut in half. It's the bottom of a preceding frame and the top of a following frame. Your dad should go back to whoever transferred the film and make them redo it.
	Not really. That adjustment needs to be made in the projector. And is very easy in real time.
 To leave it like that is sloppy and careless.
	If you can't get it scanned properly you can improve the situation with AviSynth. Especially if the framing error remains constant. It's much harder if the error moves up and down with time. And you will not be able to restore portions of the frame that weren't captured. If you can upload a sample video I'll take a look at it.
	Interesting to see if jagabo can work any magic on that.
 I was responding to a situation I have seen where the film-gate could be corrected with a control wheel so you saw a complete,steady frame at projection. Here you have a jumpy image which could be caused by the film or the projector or both.
  Method for cleaning 8mm transferBy film in forum RestorationReplies: 23Last Post: 11th May 2020, 20:30
  super 8mm transferBy tom_nito in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jul 2017, 20:02
  8mm film transfer tutorialBy videofred in forum RestorationReplies: 1Last Post: 27th Apr 2016, 09:38
  Looking for some 8mm transfer adviceBy Bruce/Fl in forum RestorationReplies: 12Last Post: 17th Jul 2014, 00:17
  Looking for advice on 8mm film transfer optionsBy Gordon F in forum Newbie / General discussionsReplies: 11Last Post: 27th Jun 2013, 18:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
