How to restore this video?
What do you mean by restore? What specifically?
Doesn't look that bad to me -
You can make the frame larger but you can't restore lost detail. The best you can hope for is to keep the edges sharp without creating aliasing artifacts. And maybe remove some of the compression artifacts/noise. Since reencoding with a lossy codec will lose more detail and create more artifacts you'll need to use a higher bitrate. In the end, you'll end up sending a lot of time and effort to get a video that's only very slightly better than the media player's scaling of the original to the same size. It's usually not worth the effort.
How to get good quality improving underground rock music video?
By ciccioschumacher in forum RestorationReplies: 8Last Post: 11th Oct 2017, 10:39 -
Improving Picture Quality
By Teac23 in forum RestorationReplies: 5Last Post: 23rd Feb 2017, 09:51 -
Need Help For Improving Video Quality
By amyjames in forum Off topicReplies: 4Last Post: 11th Aug 2015, 10:19 -
8MM Film & Improving Quality
By newsgroup guy in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2013, 05:36 -
Help improving video quality (streaming)
By NRL in forum Video Streaming DownloadingReplies: 4Last Post: 21st Dec 2012, 09:45
