Hi,
I need help on converting a DivXAvi 352x288 to a MPEG1 VCD or MPEG2 SVCD and play it on the DVD/VCD Player on the TV. But i want to make the quality and resolution same as my original DivX movie. What settings should i put? Really need help.
Cheers.
Look at the guides.
AVItoVCD
You can make a VCD out of it. The input resulution is to small for SVCD. And dont hope too much, because DivX Quality look good on your PC, but not allways on TV.
TTooLs DVC2 and MPEG Site
Sorry, but you can't. The VCD will have to be either shrunk or stretched.
In your situation, VCD is what you want, which is 352x240 so is pretty close to what you have...
Now, this MIGHT work...
In TMPGEnc, make a XVCD (check out the tutorials on this site), and set the video output to 720x480, and then in the source file settings (in Advanced, I think), set it to CUSTOM spect ratio, and change it to the resolution you want (what matches your video).
I tried that with a 640x360 stream at 352x240 VCD, and I could only see a part of the screen. That suggests to me that those settings I made in advanced forced it to keep the aspect I set in Advanced. -
This can maybe work just fine, your file is in PAL output format, what our friend GUTB is referring to is the NTSC format.
I think most players, at least in Europe, is able to play both PAL and NTSC formats. You have to check your documentation to see this. Just remember to check those settings when converting.
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 12:36 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
