Iam having problems encoding two dvds. One of them is "Gahndi" and the other is "Seven Samurai". They are both over 3 hours long. It seems that when Im encoding the .vob's for the movies they stop when the output avi gets somewhere near one gig. I don't know whats causing the problem. I have a 20 gig HD dedicated to dvd ripping so its not a limited space problem. I think the problem is within Flask somewhere. Does it have a limiter on it? Iam still a newbie to all of this so if anyone could help me out I would very much appreciate it.
If it helps any Iam ripping the dvds with Smartripper and Iam using FlaskMPEG version 0.594.
Thank you
When you rip for FlaskMPEG, always use the Files or Backup Mode, not the Movies, and remember to also select the IFO file, check here for more details
http://www.digital-digest.com/dvd/articles/dvdtovcd/index.htmEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
