It's like they are having trouble turning in some spots then the camcorder will stop. When I try to capture they stop every few seconds in one part of the tape. They will go for 20 minutes in another part of the same tape. I tried two different camcorders with the same result. If I press play and then press fast forward it will go without stopping. Does anyone have any suggestions on a way to get these tapes to run more smoothly. I just need to transfer to the PC. Thanks
Results 1 to 9 of 9
Hi,
how you have connected your camera to PC, and what software are you using for capture? It stops in the middle of take or at the end? By take I mean start -> stop recording video. I don't know correct word for this. Have your successfully captured video any or lots of artifacts?
Bernix -
Thanks for the reply.
I'm using firewire to an older XP laptop capturing with Cyberlink Power Director 8. I have a newer laptop with PD14 but no firewire port. Yesterday, using the PD8 on the older laptop it would capture for some seconds and then stop. I would start it again and it woud stop after some seconds. As I said in the first post, there was a section later in the tape where it captured for 15 minutes without stopping. As it got to the end of the tape it started stopping again.
At first I thought it was the tape being difficult and the camera stopping it. After thinking about your line of questioning I tried it without the laptop turned on and it ran for quite a while. Then I turned the laptop on and started pd8 and it started stopping again. So I guess I have to find another program. -
It seems like issue with firewire. Maybe on camera side (but you said two cameras same issue) so probably on PC side. Or try change cable also, if possible.
Bernix -
According to Scenelyzer homepage it is now most probably free so not need demo version.
But I'm not expert on law, just visit their page.
Bernix -
Good idea. Thanks for the tip on Scenelyzer. I just ordered another firewire cable and will try that. Already glad to know the old tape can play. I've got many I hope to archive. I'll report back. Thanks!
What a strange problem. Let us know how it turns out.
mini dv tapes
By jamespoo in forum MediaReplies: 5Last Post: 8th Oct 2015, 06:16 -
Need help archiving some old DV Mini tapes
By donaldc48 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Nov 2014, 21:44 -
How to improve image on Old VHS tapes
By saulera in forum RestorationReplies: 1Last Post: 26th Sep 2014, 22:42 -
Import ntsc mini dv tapes on pal camera
By elangsru in forum Capturing and VCRReplies: 3Last Post: 19th Jun 2013, 04:07 -
Have Mini DV Tapes but no camera and want video
By miss teri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Apr 2013, 11:49
