Recently I have configured madVR with Potplayer using Rakens guide. My GPU is not much powerful, so I could not use image doubling. But the problem is, I am losing details even in the default settings. The video is softened, with the cost of lose in details/sharpness. Is this normal? I am new in codecs amd things, pardon me if I am wrong about something.
Specs:
Windows 10 64 Bit
Core I7
Ram 16 GB
Nvidia Geforce 960M
(Asus ROG GL552VW)
Your specs seems powerful enough. I used to use MadVR also, but switched to EVR custom present, because it is simply for me better handling mkv files.
Try read this as it was updated on september this year. And this.
BernixLast edited by Bernix; 22nd Nov 2017 at 14:29. Reason: added link And this
As you said, I have a decent config (not the best, but good to go), but still image doubling makes thing worse. Reading the settings guide you provided, I applied settings that were listed in GTX 970, and the result was worse. With the current working madVR setting I have (as said in Rakens guide), everything works fine but the image is softened and details are gone, as mentioned before.
MadVR vs LAV
By snadge in forum Software PlayingReplies: 26Last Post: 13th Dec 2019, 15:47 -
Saving current frame w/ Potplayer + madVR, not saving madVR effects
By LJay in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2017, 15:14 -
What madVR can and cannot do
By DiscoPedo in forum Media Center PC / MediaCentersReplies: 17Last Post: 3rd Jun 2016, 15:28 -
madVR Problem
By haithomy in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2014, 22:47
