Hi,
I want to cut a 1.61 GB MKV file with Avidemux but I get the message "if the file is using B-frame as reference it can lead to a crash or stuttering, Avidemux can use another mode which is safe but you will lose frame accuracy, do you want to use that mode"? I don't what I should do and hope to get some help on this forum.
Thanks and have a nice Thanksgiving!
Serge
Hi,
if you just want cut gop 1st part (1st frame, last frame (somewhere in half (one frame before Keyframe that start second part))) 2nd part start (Keyframe (it is (I) frame type in avidemux), last frame of the video)
And Video set to copy, audio set to copy output format probably also MKV, I don't see any problem. Type of frame (I) is on 90% keyframe. It is fully described picture independent on any previous or future frame.
And if you want cut on p or b frame (start of selection) you have to re-compress whole video. But it should be also o.k. when re-encode whole video.
So find Keyframe where you want split your video go one frame back and click on B mark below timeline for selection (to be sure click it twice) When done click delete, it will delete first part and if you follow this, your second part should start at I frame, so no need do selection, just save it copy video copy audio and output format.
Or there is also easy way to split in Mkvtoolnix. It is not frame accurate, but probably better. In output, split mode choose what is suitable for you. And you get 2 or more files depending on your split file option.Last edited by Bernix; 22nd Nov 2017 at 13:09. Reason: typo
Hi Bernix,
Thanks for all your information. I'm not familiar at all with editing videos only with converting but I will review your explanation after Thanksgiving and follow your directions.
Thanks again and have a great day.
Serge
Webm/MKV file crashes on Machete edit-save and makes mess in Avidemux
By gumbygum in forum EditingReplies: 6Last Post: 19th Mar 2017, 15:44 -
Replacing DVD Movie file with demuxed Mkv file while keeping original Audio
By DeusExMachinaN7 in forum Authoring (DVD)Replies: 5Last Post: 9th Oct 2016, 14:44 -
Fix MKV file or converted M4v file - bad spot
By wdpcpa in forum EditingReplies: 2Last Post: 4th Feb 2014, 18:49 -
converted .mov, reference file deleted but the file has a video track.
By cdtsly in forum Video ConversionReplies: 5Last Post: 13th Nov 2013, 14:30 -
MXF Reference file
By Martynguk2002 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2013, 08:48
