Hi,
I am trying to capture HDV 720p tapes on a JVCHD101 Pro Camera. This is the same camera that took the footage.
I have been given the camera and over 200 tapes
I am using HDV split 0.77 beta.
According to the file properties, I have captured a 26 min Video clip. When I play the video clip in Media Player it runs for 26 min.
When I import into Sony Vegas 12 or Sony Home studio 11 or other video conversion software, it shows that my file is only
a 1 min file ???
I am totally beat on this one.
I just did another test file for 3 mins and it played for 3 mins in Media Player. Then I did another test capture for about 1 min
and it played back for 26 min ?????????????? in media player.
I normally capture HDV 1080 into Vegas or HDV split with no problems in the past.
I have tired capturing with both Vegas 12 and Home studio 11, but both programs crash on the initial first half second of capture.
Yes, I have changed firewire driver to legacy as well, but still wont work with Vegas.
Any help Please. Especially on why Sony Vegas Cant even start capture
cheers
Scott![]()
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Nothing makes Sense
This files is 1 min 40 second and is 130mb
I just did another file @ 18 seconds and it was 7gb
General
Complete name : D:\Dallas HDV 720p\HDV_Norfolk 2 again-0001.m2t
Format : MPEG-TS
Commercial name : HDV 720p
File size : 130 MiB
Duration : 1 min 40 s
Overall bit rate mode : Constant
Overall bit rate : 10.9 Mb/s
Maximum Overall bit rate : 19.7 Mb/s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High 1440
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=6
Codec ID : 2
Duration : 1 min 39 s
Bit rate mode : Constant
Bit rate : 9 936 kb/s
Maximum bit rate : 18.3 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.216
Time code of first frame : 00:05:30;34
Time code source : Group of pictures header
GOP, Open/Closed : Closed
Stream size : 118 MiB (91%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : 5 ms
Stream size : 4.59 MiB (4%)
Menu
Menu ID : 1 (0x1)
List : 4096 (0x1000) (MPEG Video) / 4098 (0x1002) (MPEG Audio) / 3842 (0xF02) ()
Maximum bit rate : 19760000Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system. -
this is suspicious. Try open file in avidemux. It should get it on first frame, which isn't at timeline at 0 time. Then press mark B on the bottom, and delete selected. Set video to copy, audio to copy and output format what you want. But of course don't overwrite original file!Time code of first frame : 00:05:30;34
Then save it and let me know if file size and times are correct.
Bernix
This is what happens when capturing in Vegas 12 OR Home studio 11 ( same software Im guessing anyway )
This happens on several win 7 64 i7 computers and a Xeon PC as well
It crashes on the very first frame. I can hear a blurb of audio and then the pop up screen from Vegas asking to send or not to send info
Please bear in mind, this doesnt happen on dv capture or HDV 1080 from my canon hdv players.
Its only this borrowed jvc HD101 beast with 720p tapes
any ideas about getting vegas to capture would be great
Extra Information
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\dx_video_grovel_x64.log
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\svfx_video_grovel_x64.log
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\ocio_x64.log
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\dx_grovel_x64.log
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\vst_grovel.log
File: C:\Users\user\AppData\Local\Sony\Vegas Pro\12.0\gpu_video_x64.log
Problem Description
Application Name: Vegas Pro
Application Version: Version 12.0 (Build 394) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 12.0\vegas120.exe
Fault Address: 0x00000001406F8B9B
Fault Offset: 0x0000000000858B9B
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 12.0\vegas120.exe
Process Version: Version 12.0 (Build 394) 64-bit
Process Description: Vegas Pro
Process Image Date: 2012-10-26 (Fri Oct 26) 02:11:42Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Help Needed to Transfer & Capture HDV/DV Tape Footage
By TheCinematicRose in forum Video ConversionReplies: 5Last Post: 9th Aug 2016, 10:42 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 16:42 -
Need help capturing 720p HDV tapes to Mac
By moxiecat in forum MacReplies: 15Last Post: 24th Apr 2014, 16:56 -
HDV Capture in Premiere MPEG, not AVI
By DigitalRootsStudio in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Apr 2013, 14:19 -
Can no longer capture HDV from Canon H20
By bemused in forum Capturing and VCRReplies: 29Last Post: 25th Mar 2013, 15:50
