Dish TV just installed some new receivers here yesterday and guess what...no coax output, just HDMI and the three RCA tv outlets (Red, Yellow & White). I still have a couple of old TV's that I would like to use the COAX input in the rear of the TV versus the front facing RCA 3 connections.
Does anyone know of a HDMI to COAX connector that will work?
Note that the Dish technician stated that the RCA output displays a better picture than COAX which was contrary to what I have been told previously.
Extraordinary claims require extraordinary evidence -Carl Sagan
Most here at VideoHelp agree with the Dish technician that RCA is a higher quality connection than coax.
At least one HDMI to coax converter exists: https://www.radioshack.com/products/radioshack-hdmi-to-coax-adapterIgnore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks for that link. I was hoping that it would be a simple connector to connector thing but I see it has to be a converter.
Extraordinary claims require extraordinary evidence -Carl Sagan -
That is right. A simple connector-to-connector adapter won't work. The digital audio and video from HDMI need to be converted to analog, then the analog audio and video have to be processed by an RF modulator to produce an NTSC channel for output via coax.
Connecting an RF modulator to the satellite receiver's composite video and stereo audio ports would also output an NTSC channel over coax.
However, connecting the three RCA tv outlets on the satellite receiver directly to the matching connections on the analog TV would be simpler, less expensive, and more reliable than the other options above.Ignore list: hello_hello, tried, TechLord, Snoopy329
HDMI to COAX?
By sethrose in forum DVB / IPTVReplies: 15Last Post: 22nd Apr 2016, 17:36 -
2xHD camcorder HDMI out to HDMI in capture card (Thunderbolt)
By a1s2d3f4 in forum Capturing and VCRReplies: 17Last Post: 26th Jun 2015, 22:18 -
Picking out a video card...... is mini-HDMI as good as regular HDMI?
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 12th May 2014, 13:00 -
How to connect pc to TV by HDMI cable if the pc has no HDMI but USB port?
By coody in forum ComputerReplies: 3Last Post: 7th Dec 2013, 05:55 -
Mating BLU-Ray HDMI TO DLP TV w/no HDMI input.
By basildean52 in forum Newbie / General discussionsReplies: 6Last Post: 17th Feb 2013, 12:19
