Hi all,
I've a big problem. My gfriend sent me a Sylvania SDVD1030-B and I can't unblock multi-region. I need to hack it to see in all regions.
Anybody can help me?
Thank u in advance
Results 1 to 9 of 9
You can find solution when you search for it in top of the page next to Software....
try this
Power on with no disc inside
Press SETUP
Press the RIGHT arrow key until you get to the "Preference Page"
Enter 9,6,5,3
Use the UP/DOWN arrow keys to select "0"
Press ENTER
Press SETUP -
Hi BzERK IE,
no, I tried with this code but isn't valid for SDVD1030-B. It's only valid for SDVD1030
There are "all" known dvd region free codes.
I don't think if someone knows it, and not published it there, he will not also answer here. -
I noticed, that sometimes it works for different model also. So you can try other Sylvania types.
For my (i don't need it) blu-ray there was some codes, but in response they didn't works, but I found on different model answer, that it works for model I have. So just try some different models. Maybe some will work. -
Sylvania sdvd6672uk
By Strebor_ in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Aug 2017, 02:49 -
How to set the Sylvania SDVD1032 as Region 0 (Region Free)
By jharris1993 in forum User guidesReplies: 0Last Post: 7th May 2017, 21:19 -
Need Sylvania SDVD 7014 Remote
By brokenfinger in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2015, 18:15
