Have few mixed Laser discs DTS and AC-3 and want to capture them to computer to make m2ts files with either DTS 5.1 or AC-3 5.1 (Maybe authoring to Blu-ray later), I will be getting a LD player with component out (Not sure what LD uses RGB or YPbPr ?) and an RF modulator for the AC-3 part, My question is: Is there a single capture card that can accept component and SPDIF/Toslink at the same time without having to do the video part and the audio part separately and then Mux later?
I'm aware that there are devices with component and HDMI inputs but not sure about Coaxial/Optical inputs. In that case maybe use Coaxial/Optical to HDMI adapter?
What about the capture software? Once again is there a single solution capture software or it has to be done separately with 3rd party codecs in a workflow?
Results 1 to 1 of 1
Which device can capture component video in 10bit 4:2:2 color?
By digicube in forum Capturing and VCRReplies: 11Last Post: 30th Oct 2016, 14:08 -
Problem Muxing Raw h264 and Raw AC3
By Malonn in forum Video ConversionReplies: 14Last Post: 29th Jan 2015, 16:21 -
Ezcap HD Video Capture device any good? HDMI/Component
By ezcapper in forum Newbie / General discussionsReplies: 44Last Post: 18th Dec 2014, 18:47 -
Recommendation for S-VHS Component Capture Device or Card
By timothyd_1975 in forum Capturing and VCRReplies: 56Last Post: 11th May 2013, 14:04 -
What is the cheapest HD component (YPbPr) USB capture device you can find?
By Brad in forum Capturing and VCRReplies: 5Last Post: 28th Jan 2013, 22:27
