Hi there,
I had been using it to capture some Simpsons episodes when all of a sudden when I went to capture last weeks episode today, the audio was not capturing. I've made sure the 'Capture Audio' box was checked but I dont know whats wrong. How could I have triggered this to not cpature the audio?
When I right click on the screen of the capuring, you know it finishes the capture process and at the bottom of the screen it tells you the amount of frames captured, duration of the video and audio in bytes captured...I obviously captured the sound but when I go to play it back it doesn't come up...any ideas?![]()
My Specs:
1.2GHZ Athlon
Windows 2000
384Mb RAM
WinTvGo Hauppauge TV Card
Steve.
If you capture your audio via the line in on your sound card make sure you hav'nt accidentally muted it.
Craig -
Yup, I knew it was something silly like that...
Sorry to bother you with this silly problem...I didn't even change the settings and the line in box wasnt selected which I found odd. Oh well...thanks again for your help.
Capture from camera-no sound
By Mållgan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2011, 11:43 -
WinDV - Hear sound during capture?
By scormodo in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2010, 11:41 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Intermittent sound on mini-DV capture
By adamj_ut in forum Capturing and VCRReplies: 5Last Post: 17th Nov 2009, 18:47 -
EasyCAP 2.0 USB = No Sound on Capture????
By williamgibbs in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2009, 09:15
