Hi,
I downloaded Valerian the other day and extracted the MKV to audio and video files. Because the audio was ATMOS I run it through eac3to to get a compatible file and then remux them with TS Muxer as a Bluay iso and burn with Image Burn to BDR25. When I play this disc on my PC it plays fine at the correct aspect ratio but when I play it on my XBOX ONE the aspect ratio is stretched vertically. I can put the BDR back in my PC and play it through VLC and I get top and bottom borders and correct ratio. I've inspected the original MKV video file and compared it to the burnt mts file and both are identical resolutions but the XBOX ONE S won't give me borders. This also happened with Spider-Man Homecoming.
Any ideas?
Closed Thread
Think I've worked it out but not sure how to fix it. The MKV for the off files is only 1920 x 808 and the small icon for the movie shows this and there are no borders. On checking a film that works it's full 1920 x 1080 with borders present. But how can I add borders to the other movies?
I've figured out that MKVToolnix can change the display pixels and video pixels but I'm unsure what to change here to make it play correctly
uncropMKV was designed for problems such as yours.
But since you're asking for help with a copyrighted film you downloaded illegally, you aren't allowed to ask and we aren't allowed to help.
Yes the film plays fine from a thumb drive. It's TSMuxed to a Bluray ISO image. The issue I can see is that other conversions I've done the MKVs have been 1920 x 1080 with bars top and bottom. This movie is 1920 x 808 with bars removed. When I play it on my TV it stretches it to fit vertically.
DVD to XviD conversion, Aspect Ratio, Scan Type and Macroblock issue
By Orso_siberiano86 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2017, 12:21 -
the simpsons blu ray aspect ratio makemkv issue
By wonko_insane in forum Blu-ray RippingReplies: 1Last Post: 23rd Jun 2017, 22:31 -
VIrtualDub issue with aspect ratio
By david.dgc in forum EditingReplies: 17Last Post: 8th May 2017, 00:12 -
Aspect Ratio Issue
By Robert the Bruce in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Dec 2014, 12:55 -
Potplayer - aspect ratio issue
By rigger67 in forum Software PlayingReplies: 4Last Post: 13th Apr 2014, 11:19
