    May 2001
    Eric
    If I'm encoding with VBR, what is a reasonable minimum and maximum for DVD-R?
  2. i use 3000 and 8500 and am usually very satisfied with the results...
    Oct 2000
    Ireland
    Max DVD bitrate is 9800 , so I substract the audio bitrate to find out the max video bitrate.
    If I do TV captures I'll encode the audio at 224 , so max video = 9576
    If I audio is 448 ac3 then the max video = 9352
    When I analyze the encoded video with BitrateViewer I never saw a peak at my maximum bitrate. I think the highest I've ever seen is around 7000.
    This works for me with A03 burner and 1.49£ DVD-R.
    uteotw
  4. Member shardison's Avatar
    Mar 2001
    California
    Try TMPGEnc's CQ mode instead of 2 pass VBR. I use 2000/6000 and the average comes in at about 3500kbs and no artifacts. (Old)2-pass has freaked out my DVD player for some reason. You can fit a lot of nice video on a DVD at 3500kbs.
    May 2001
    The DVD standards are as follows:
    MAX VIDEO BR = 9.8Mbps
    MAX AUDIO BR = 912kbps
    MAX STREAM BR = 10.08Mbps
    I believe that the minimum video BR is 500kbps.
    So, as a practical matter, using 384kbps audio, I set my MAX VIDEO BR to 9.5Mbps and my minimum to 1Mbps. Depending how much data I have, I set my average BR from 3.5Mbps to 5.5Mbps (usually 4.5Mbps).
    But, as usual, your mileage may vary.
