Used MKVCutter and MKVToolNix to try and cut a few second section so I could convert to GIF. I used keyframe before where I wanted to cut and second keyframe after since it's easier to edit out extra frames in GIF. I keep getting corrupt video that looks like 4 video (like the security video footage) and in acid-tripping mess of color. I tried going back additional keyframe for the start, I get same messed up result.
https://youtu.be/32k_6y7cZuU is what I get.
The original video plays fine in MPC-HC and VLC. The preview in MKVCutter and such shows normal video so it appears to me something is getting broke when I cut the video. Any idea or suggestion? Video to GIF I've used don't like dealing with 90-minutes long video and Photoshop only works with the first 500 frames. I haven't tried online EZGIF site since my upload is capped at anemic 64Kb/sec and it would take me a day or 2 to upload the 1GB video file.
Be sure you are cutting BEFORE the keyframe of what you wish to retain. Different players, editors will vary on which is a keyframe and some count from 0 and editor may count from 1. Also filters such as trim have their own counting system if you use them.
This looks like the absence of a starting keyframe in an mp4 container. I have had good luck using AVIsynth:
Code:FFmpegSource2("C:\Users\Bud\Desktop\[dp]Manjandani-1.mp4", atrack=-1).Crop(0,0,-0,-0).LanczosResize(720,304) ScriptClip(Last, """Subtitle("[ "+Chr(FFPICT_TYPE)+" ]", size=(Height*56.0/720), align=2)""", after_frame=true) Subtitle("C:\Users\Bud\Desktop\[dp]Manjandani-1.mp4", x=720, y=324, font="Arial", size=24, text_color=$ff0000, align=3) Subtitle("This is Anamorphic video", font="Arial", size=24, text_color=$ff0000, align=5) ShowFrameNumber(scroll=true, x=10, y=27, font="Arial", size=24, text_color=$ff0000) ShowTime(x=72, y=44, font="Arial", size=24, text_color=$ff0000) ShowSMPTE(fps=23.976, x=68, y=61, font="Arial", size=24, text_color=$ff0000)
[Attachment 43774 - Click to enlarge]
In this case I make sure frame 86 is the first frame of my retained clip and so far it has worked..
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Corrupt Video Files
By i7970796 in forum Newbie / General discussionsReplies: 3Last Post: 13th Jul 2015, 14:55 -
Software to edit/cut/merge/convert MKV audio and video @ original bitrates
By Yanta in forum Video ConversionReplies: 9Last Post: 19th Oct 2014, 15:11 -
How to cut any video with the free Video to Video Converter
By Baldrick in forum User guidesReplies: 12Last Post: 26th Apr 2014, 06:31 -
Cut part from video and cut subtitles as well
By aapje in forum Video ConversionReplies: 7Last Post: 8th Feb 2014, 10:11
