  1. Ha all.
    Is possible get a file with Luma value frame by frame from a clip?
    Thanks in advance.
  2. Regular ffmpeg can do this trough
    ffmpeg -v quiet -stats -i "%1" -vf:? "signalstats,metadata=print:file='v.%~n1.txt'"
    - have no Apple so don't know if this is possible by ffmpegx.
  3. Hi Pandy
    In this moment i'm working with PC
    With:
    ffmpeg -v warning -stats -i 59.mp4 -vf "signalstats,metadata=print:file='v.%~n1.txt'"
    program say me:
    Trailing options were found on the commandline.
    At least one output file must be specified
  4. Originally Posted by barabba2005 View Post
    Hi Pandy
    With:
    program say me:
    Try something like:
    @setlocal
    @set name=59.mp4
    @ffmpeg -v warning -stats -i "%name%" -vf:? "signalstats,metadata=print:file='v.%name%.txt'"
    @endlocal
    @exit
    or explicitly use name in output result like:
    @ffmpeg -v warning -stats -i "59.mp4" -vf:? "signalstats,metadata=print:file='v.59.mp4.txt'"
    You receive error due replacing argument for batch with real name but remain part of script is not changed to so filename is unknown - no valid name at the output - i usually avoid hardcoding filename in script and provide filename as argument to script - assuming that script is named ffvideostat.cmd then i call my script like this ffvideostat "myvideofilename.mp4" and result will use name and extenssion like this v.myvideofilename.mp4.txt
    btw in future try to use different forum - ffmpegx is forum focused on particular application (ffmpegx which is not popular in Windows world as much as on Apple world).
  5. OK
    Unfortunately it doesn't write TXT file
    Do you know a Windows forum with a lot experience like this?
    Thanks a lot
  6. Search videohelp where ffmpeg questions are solved, general discussion looks OK IMHO.
    And my fault. please add
    -f null -
    at the end
    whole command should look like this
    @ffmpeg -v warning -stats -i "59.mp4" -vf:? "signalstats,metadata=print:file='v.59.mp4.txt'" -f null -
    sorry for too quick copy&paste - this was my original batch and i simply forget to tell ffmpeg output - apologies.
    @ffmpeg -v quiet -stats -i "%1" -vf:? "signalstats,metadata=print:file='v.%~n1.txt'" -af:? "astats=metadata=1:reset=1,ametadata=print:file='a.%~n1.txt'" -f null -
  7. Thanks a lot.
