So I've got one of the old Panasonic DVD cameras i can get videos from the discs fine but my problem is the meta data of date on the files. So on the camera when i put a disc in the correct dates show up on the recordings, on PC when i play the disc on the topo menu the dates are correct but the metadata for the actual dates on the files in explorer are incorrect. When i put the disc in the camera and connect the camera with Panasonic video suite the dates are also incorrect. This happens with all of my DVDS what I want is to get the recordings to files with the correct date on the file. I would not like to manually change the date on the files. Any help is appreciated!
It is either stored in a separate metafile in the dvd filesystem (for instance, something like \root\VIDEO_TS\USERDATA.DAT), or in private user data fields/packets embedded or multiplexed into the mpeg video files.
Check mediainfo on some sample files and you may find them that way.
Issue with Panasonic DVD-Recorder DMR-EH55
By chudbeagle69 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 9th Oct 2016, 14:47 -
DVDs made from DVD Recorder - Issue copying files to PC
By Davems4519 in forum DVD RippingReplies: 14Last Post: 9th Nov 2015, 09:28 -
Panasonic AVCHD MTS to MP4, with file Create/Modified Date + Metadata
By stevebor1 in forum Video ConversionReplies: 1Last Post: 17th Aug 2015, 04:12 -
Conversion from MiniDV to DVD for Panasonic NV-GS6GC Digital Video Camera
By Hesham_3del in forum Video ConversionReplies: 4Last Post: 8th Aug 2013, 17:46 -
Panasonic DMR-EH53 record to DVD-RW issue
By stigj in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2012, 09:40
