Hello,
I subbed an 1h14min long video file, but it was only a temporary file until i could get my own on the proper one.
The proper one however starts at the same moment but ends 2min earlier, because it seems to be slightly faster. It makes the whole subtitle file i made useless after 1min and 30 seconds into the file
Is there any way i could somehow speed up the subtitle file so that the last line ends at 1h12min, aka synced to the proper video file?
I searched a bit around ffmpeg and Aegisub but there doesn't seem to be any such option., and slowing down the new video file is not an option.
I already started retiming everything but it will take days to complete
Thanks for the help
Almost every subtitle program has two point synchronization. You set first subtitles time and last subtitles time and it will strech it according to this points.
Edit: Probably you have 23,976 subtitles for 25 video, or other way round. Every program (subtitle) has this conversion between framerates too.
Bernix
Cut static image sections from start, end of video (and middle?) with Linux
By KarmaPolice in forum LinuxReplies: 4Last Post: 16th Aug 2016, 03:04 -
Trimming start and end off multiple files
By hapsee in forum EditingReplies: 1Last Post: 7th Feb 2016, 08:26 -
Split subtitle in 12 parts by the end of the video
By Username2013 in forum SubtitleReplies: 2Last Post: 14th Jan 2016, 11:29 -
Basic NRE for Windows that can re-encode at given start/end frames?
By yetanotherlogin in forum EditingReplies: 4Last Post: 26th Feb 2015, 03:44 -
Video clip name - 5 seconds in start - subtitle
By pcspeak in forum EditingReplies: 0Last Post: 19th Dec 2014, 17:02
