Why can't they just keep supporting both?
They claim it makes browsing more secure. But I never had an add on virus.
They now followed the same concept as #HyunYeulLee.
Results 31 to 60 of 72
Day late info, but Noscript it seems is available for 57
EDIT: missing temporary allow, possibly my fault. But it looks very different.
BernixLast edited by Bernix; 21st Nov 2017 at 12:21. Reason: EDIT
Thanks for that info Bernix. Link is here: https://noscript.net/getit
BUT, since I use the "temporary allow" alot, I will wait a few more days to see if they fix that.Extraordinary claims require extraordinary evidence -Carl Sagan -
Better to make sure, it is only for Firefox 57 and higher
https://addons.mozilla.org/en-US/firefox/addon/noscript/ -
I know, what you mean. But isn't name of the thread about itBetter to make sure, it is only for Firefox 57 and higher
Maybe my fault, there is custom per site mention on NoScript homepage. But I really can see how to.BUT, since I use the "temporary allow" alot, I will wait a few more days to see if they fix that.
When I used other blockers prior this release, I was able block for example news.youtube.com on youtube.com page. In noscript you allowed all youtube or block whole youtube. I felt better control. Now I have to lean on NoScript functionality and security.
In option is only white listed domain and allow all (dangerous)
And here is picture what you can do from browser
[Attachment 43808 - Click to enlarge]
It is very minimalistic from my POV.
So I kept uBlock Origin in not advanced or how is it mode.
EDIT Now I see the fourth icon is custom
[Attachment 43809 - Click to enlarge]Last edited by Bernix; 21st Nov 2017 at 17:34. Reason: EDIT
I had to go back to version 56 and to turn off the auto-updates. The reason is the 57th doesn't support the older AddBlockPlus plugin, important for getting hidden links to videos (since version 3 this ability was removed from the plugin).
Just been having a look at NoScript. I don't like the new setup so I shall stick with uBlock Origin as I thought I would.
Bernix, instead of Never remember history, why not select Use custom settings for history and set it to delete the history when Firefox closes. That way add-ons work normally, apart from those that don't work in Private mode when you use it. -
Hi,
I'm never used history. But it somehow remember history too in my settings. I can open closed tab, go backward and forward. Only it in most cases doesn't show visited sites in history - show history. That is all. So I'm satisfied with what I got.
I will use new NoScript, but supported with uBlock origin in default settings.
Thank you
Bernix -
new update of NoScript recent changes
+ Added "Revoke temporary permissions" button
+ Added "Temporarily allow all this page" button
x Simplified popup listing, showing base domains only (full
origin URLs can still be entered in the Options window to
further tweak permissions)
x Fixed UI not launching in Incognito mode
x Fixed changing permissions in the CUSTOM preset affecting
the DEFAULT permissions sometimes
x Fixed UI almost unusable in High Contrast mode
x Fixed live bookmark feeds blocked if "fetch" permissions
were not given
x Fixed background requests from other WebExtensions being
blocked
[Attachment 43816 - Click to enlarge]
BernixLast edited by Bernix; 23rd Nov 2017 at 08:17. Reason: added picture
Does that new NoScript remember all allowed or blocked scripts from past version (under Firefox 56)? So websites follow the same patters like before, or does it all need to be overhauled, set up again?
I don't know to be honest. I deleted all addons that was incompatible with 57. Maybe when you install it it will remember, but as I say, I can't confirm it. But doubt about it.
Bernix -
I upgraded to ff57 and the new NoScript. It remembered all the whitelisted sites from the old version.
I just tried to use Video Download helper. It did download but the video won't play for some reason. Is it just me or someone else have seen this as well?
Thanks -
I tested that combo , new Firefox 57 and new NoScript. It seams to work in a sense blocking scripts but I have problem just allow some of them. It always blocks them again after refresh. I might be something missing or that script does not work as it should. The author might know about it but it is out there because of huge demand and it will take more time to tune it up.
I have no problem, downloading and playing video.I just tried to use Video Download helper. It did download but the video won't play for some reason. Is it just me or someone else have seen this as well?
I think that should be through custom settings, fourth icon from left. I also noticed, when you entered some other side of same page, there are other things to block or custom settings. So as you say, long training.I tested that combo , new Firefox 57 and new NoScript. It seams to work in a sense blocking scripts but I have problem just allow some of them. It always blocks them again after refresh. I might be something missing or that script does not work as it should. The author might know about it but it is out there because of huge demand and it will take more time to tune it up.
Edit: I have to say, that NoScript is good for sanitize XSS. Very useful. For example on IMDB.com.
BernixLast edited by Bernix; 25th Nov 2017 at 03:59.
Ad NoScript -AL- you can do lot in option and then in bottom left Debug. There you can manually change and add what you want. Maybe it helps you.
v 10.1.3rc1
+ Work-around for Firefox not displaying NOSCRIPT elements on
pages where scripts are blocked by CSP
+ The Alt+Shift+N shortcut now opens the NoScript UI also on
windows with no toolbars containing NoScript's icon
x "unsafe" (non-HTTPS) matching is now automatically selected
on non-HTTPS pages (fixes the perception that you set a
site to TRUSTED and it reverted to DEFAULT)
x Full addresses are shown again to be choosen in UI, together
with base domains
x Better auto-reload logic
x Fixed NoScript back-end to work also if sync storage is
disabled (thanks Rob Wu for reporting)
x Fixed potential fingerprinting through placeholder icon
(thanks Rob Wu for reporting) -
I get the security thing but really hate it when FF change so much stuff that everything you use ie extensions are taken away from you to do what you want out of your browser. Just about all of my extensions are gone. I have to look for replacements and can not find any. Really makes me mad. And most of all FF now looks like Chrome and I hate the format. Plane looking with no depth in any of the icons, no color to make it look good. Hope that some of my extensions will catch up and can be used again.
If it feels good, do it. -
Backpain, you can check some info here https://arewewebextensionsyet.com/
And maybe you can say, what is your most "missing" extension and probably somebody will help you.
BernixLast edited by Bernix; 27th Nov 2017 at 08:03. Reason: somebody :)
Another update of NoScript
+ Emulated META refreshes inside NOSCRIPT elements
x Fixed close button garbled on Mac OS X and Linux
x Fixed XSS checks couldn't be disabled from Options
x More reliable auto-reload logic
Bernix -
I have to say, I'm unable after update of NoScript login to my email. Got generic js exception. Don't know where is problem, but it is related to NoScript. And unable to watch youtube...
BernixLast edited by Bernix; 28th Nov 2017 at 10:41.
I did this all with the userchrome.css file. I have all of what I had before Quantum on the old Firefox versions. For info goto: http://forums.mozillazine.org/viewforum.php?f=38&sid=2d619653528637ee6c52adac41dffab4
That's where I got the css scripts. See example attached. Be patient and it will pay off. Quantum is really good!! New extensions will be coming. Then, I can reduce my css file.Last edited by pepegot1; 28th Nov 2017 at 11:31.
just installed this noscript firefox extension and ---- so far so good !!
Another quick update of NoScript
v 10.1.4
x Fixed script enablement feedback dependant on page's own
CSP (thanks Rob Wu for reporting)
x Fixed MSE detection injection using window.eval (thanks
x Fixed window being resized and NoScript UI shown in a
separate popup when triggered on a maximized window
x General performance improvement by removing unnecessary
asynchronous webRequest listeners
Such quick updates arise doubt in me. -
Has anybody read new permission that needed new noscript?
*Download files and read and modify the browser's download history?*
Does anybody know why is this needed?
Bernix -
Just tried the latest downloadhelper and the companion app but the video would constantly stuck while playback.
i disabled the new noscript in the latest version of firefox. too many websites wouldn't load at all, it is worthless. i do like the new opera browser with built in vpn though, works well and is fast enough to be usable.
I have to say, I am ok with it, each page domain on a web page has more choices to be blocked (script, media, object ...)
I have actually other experience, from previous versions I know what domain to set to custom and now it is possible to go a bit further.
If a web page shows lots and lots of domains and it is not working, I pass. That is a no web page but a weapon of some sort, mask as a web page pretending to give you some information. Main media including. If it is working for reading or just if one or two domains need to be customized (web players) and it is a known web page it is sort of ok. But sites that do need to customize 5 domains to be able just to read something, disable adblock to read it as well, that is not a worthy web site.Last edited by _Al_; 15th Dec 2017 at 01:57.
The new NoScript is unfriendly-to-use garbage. I want words, not obtuse icons where you don't know what does what until you click and see. That UI change was pointless, something nobody asked for. I've swapped to ScriptSafe, which is what I use on Opera and Chromium.
vBulletin 3.x WYSIWYG and NoScript was the only reason I kept using Firefox.
I've frozen updates on my main system, and will use it until sites start to reject it as "too old" (like my bank). And that time, I'll probably swap to Opera entirely. Never thought I'd say that!Want my help? Ask here! (not via PM!)
Alternatives to Firefox Quantum : add-ons included
By devilcoelhodog in forum ComputerReplies: 18Last Post: 5th Jan 2019, 10:22 -
ffmpeg 1080p firefox add on youtube downloader
By krohm in forum Video ConversionReplies: 9Last Post: 30th Apr 2017, 13:44 -
How to download a video with the Firefox add-on HDS Link Creator
By uk.francis in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2016, 10:48 -
Firefox browser to add video chat
By TreeTops in forum Latest Video NewsReplies: 3Last Post: 17th Jan 2015, 22:23 -
using motion graphics as add ons in premier elements 11
By snowtiger613 in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2014, 01:01
