I have MKVToolNix GUI v17.0.0. I insert my file. I go to output and say "after specific timestamps". I need to trim off the first 4 seconds of a video. It seems the minimum it will do is 13 seconds. If I do over 13 seconds it splits it fine, but anything under 13 seconds it trims my video file to 13 seconds.
It depends on position of KEYFRAME. If you want precision cut, you will have to re encode the video.
Bernix -
Or use a "smart cutter" like Solveigmm Video Splitter and just encode around the cut(s) and copy the rest.
I actually found something already. I was browing my hard drive since I haven't done stuff like this in awhile, but know I have other software lying around. Turns out I have MKV Cutter in my Downloads folder. It was very easy to use, took only a few seconds. Just say where cut start was, hit add to cut list, hit commit cut list, select a output folder and a temp folder and done.
It works in same way as Videobruger software suggested, but glad you manage it. It looks like good program and for free!
Bernix -
Search "Split Large Video into Small Parts by File Length" on Google, choose one software you like to split video file.
Possible split bug when using seconds
By pbraine in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2014, 12:09 -
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 07:23 -
Batch replace first 20 seconds of about 50 MKV-Videos
By Vlaves in forum EditingReplies: 2Last Post: 3rd Apr 2013, 06:52 -
Split mkv file no playing correctly
By mchild in forum Newbie / General discussionsReplies: 6Last Post: 28th Mar 2013, 10:02 -
Show MKV file Time information Hour:Minutes:Seconds:Microseconds
By 5js in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2012, 02:32
