A few months ago I installed, and paid for, DVDx 4.1 from labdv and it has been great. I now get a message that it can no longer run on this machine and must be upgraded to 4.2. Downloaded 4.2 from VideoHelp and get a message that "The version of this file (DVDx 4.2.exe) is not compatible with the version of Windows you're running (Windows 7). Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher."
Nowhere on the labdv website is there an email address or Contact Us for me to do this.
Does anyone have any thoughts?
Strange of them not to provide a support email address.
Their "forum" link takes you round and round in circles. How delightful!
It's also strange that the place they link to download their software is only via VideoHelp.
Even if it was free, I wouldn't touch this software with a 100 foot barge pole.Last edited by mike20021969; 12th Nov 2017 at 03:48.
Have you tried running it in XP compatible mode? Find the executable that starts the program, select properties, change the compatibility mode settings to XP or whatever it worked in before and try again. I don't use it so I don't know if this works.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Easy ripping with DVDx 4.0
By Starbuck2010 in forum DVD RippingReplies: 41Last Post: 11th Dec 2013, 00:17 -
DVDx 4.1 Preview is out (rip DVD & Blu-ray)
By Starbuck2010 in forum Blu-ray RippingReplies: 0Last Post: 8th Dec 2013, 03:01 -
dvdx 4.0 change bitrates
By jamespoo in forum Video ConversionReplies: 1Last Post: 2nd Mar 2013, 03:31
