I have a Logo remover and would like to get rid of the TVG etc., Ratings sign in videos , are they comsidered a logo?? John
Any graphic that is overlayed on a screen can be considered a logo.
Whether it can be effectively removed is another matter. -
Yeah usually those are a solid overlay without any kind of view of what was below that "logo". Which means it will need to be entirely recreated which is usually not done well.
Hi,
think twice if you want to remove PG ratting. Its only reasonable thing to keep, logo is something different.
Bernix -
Of course it can be removed. It's just difficult to recreate what was underneath so it usually gets replaced by a blur. I use AviSynth's InpaintFunc, but there are others.
Hi guys new here introducing myself and my task at hand. Video restoration
By Dannyboy1985 in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2016, 00:20 -
what s the best settings that makes megui crop succsfuly upper video sides
By sam samy in forum EditingReplies: 22Last Post: 12th May 2015, 16:12 -
Time and volume info on the upper left corner on MPC
By miba54 in forum Software PlayingReplies: 2Last Post: 24th Nov 2014, 14:46 -
White lines in upper left corner of video
By tekslave in forum Video ConversionReplies: 4Last Post: 12th Jul 2014, 22:44 -
DVD Slideshow GUI Creating video box overlay in a corner over Slides
By toxproo in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2014, 18:50
