I found a thread about this topic in another section of the forum but the software that was discussed was for windows machines. I use Mediainfo to obtain data about MKV, TS, AVI, and MP4 HD files but the program does not list if a file is progressive or interlaced. Is there a software program (ideally freeware) for a Mac that can tell me the scan type for each of the previously listed file types?
Beware that MediaInfo only tells you if the video is encoded interlaced or progressive . It does not tell you if the frames themselves contain interlaced video. It's very common for progressive video to be encoded interlaced for PAL TV/DVD, for example. MediaInfo will tell you that video is interlaced but the frames themselves are progressive (a single picture taken at one point in time, not two half-pictures taken at two different points in time). And people sometimes mistakenly encode interlaced video as if it's progressive. That can be partially fixed by treating the video as interlaced in your editor (the chroma channels of the two fields will still be messed up).
Hi,
there is also method, I am using sometimes. In Avidemux cross platform. Open video. In filters choose yadif in top bob temporary spatial.. and click on preview. Then click on icon for next frame. If each frame is unique, the video is interlaced. At least it works for me. Don't know if is it universal solution but for me is it enough.
Bernix -
Yes, the only way to determine of the frames are interlaced is to examine them in an editor with known behavior.
interlaced or progressive scan
By devdev in forum Video ConversionReplies: 8Last Post: 11th Nov 2017, 13:09 -
Interlaced Content to Progressive
By TE16 in forum Video ConversionReplies: 2Last Post: 14th Jan 2017, 17:38 -
Determining if video is progressive or interlaced
By SameSelf in forum Video ConversionReplies: 10Last Post: 9th Mar 2015, 04:13 -
Progressive vs Interlaced questions
By Banner58 in forum Newbie / General discussionsReplies: 11Last Post: 6th May 2013, 12:49 -
About the progressive to interlaced
By 861stvideoedit in forum EditingReplies: 1Last Post: 11th Apr 2013, 04:18
