Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or try DVDFab DRM and remove iTunes movie & music protection! :)
  1. Hey,
    i don't still understand how to rip a commercial dvd.
    1) i want to rip a commercial dvd a) to dvd files (vob-files)
    b) and some others to .avi.
    What programs do i need?
    i find different programs on this forum : shrink, dvdfab decryptor, anydvd (i find this "Try install latest AnyDVD ($40)and you should be able to use DVD Shrink and DVD Decrypter or any other tool as usual. AnyDVD runs automatically in the background." does it means that i need 3 different programs?)
    if i'm right, i need a programs to remove the protecting and another to rip?
    I tried years ago, dvd fab, but i don't understand how to use it..( newbie
    thx for helping
  2. Use DVDFab to decrypt and save as a VIDEO_TS folder (this functionality is free). Then use whatever conversion software you want if you need smaller files -- like Handbrake (free) for avc/aac in an mp4 container.
  3. thx for your answer, Jagabo.
    if i use DVDfab, i don't need dvdshrink?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    NO LONGER DEVELOPED
    Latest version
    3.2 (July 25, 2004)
  5. ok thx.
    i'll try.
  6. And another good choice - WinX DVD Ripper Platinum.
    You ONLY need to install this SINGLE program, and then you can decrypt and rip DVD to VOB files or AVI or some other formats.
    It's easy to use: Click Disc to load DVD -> choose output profile (AVI video for example) ->hit RUN to begin ripping.
