hello!
What's the easiest freeware to cut parts of video files?
thanks!
Hi,
I agree with Betwixt,
my favorite for this is Avidemux, or another program able to do this is Virtualdub. But dont forget to re encode video. If you cut random part of video, that is based on GOP, you will get most probably bad start video. Or your start cutting point should start at Keyframe or (I) frame type as is in Avidemux on the bottom where timeline is is frame type. It is most probably Keyframe also.
EDIT: Flowblade seems to be linux only.
BernixLast edited by Bernix; 11th Nov 2017 at 14:02.
I use my NLE, Vegas Pro. It cannot do lossless cuts on most modern (h.264) files, but ffmpeg can. ffmpeg is not easy to use however. So, I save the Vegas file as an "edit decision list" (EDL) file, feed that to Excel, and then with one formula in Excel, I create a batch file that makes calls to ffmpeg. I then execute the batch, and it cuts the original file into individual files.
Any NLE that can save an edit decision list could work.
If this is of interest, I've posted that Excel file, and you can take a look at how it works.
[edit] The file wouldn't upload. If there is interest, I'll upload to a file sharing site and then post the link. -
Easiest freeware to record screen
By ecos in forum Newbie / General discussionsReplies: 15Last Post: 16th May 2017, 07:56 -
Freeware that can direct stream cut VOB/MPEG video files?
By kingmustard123 in forum EditingReplies: 28Last Post: 23rd Nov 2016, 10:17 -
Best way to cut out parts of a .WMV video
By buick in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2016, 01:01 -
how to Cut some parts from video
By Aashik Alam in forum EditingReplies: 6Last Post: 12th Nov 2015, 09:35 -
Cut M2V file into several parts
By nonoitall in forum EditingReplies: 2Last Post: 17th Apr 2013, 06:56
