Hello guys.
I'm trying to load the codec MSUColorEnhancement in Virtualdub without much success, I always get the following message: ''Cannot load plugin module ''C:\Users\kalemvar\Desktop\VirtualDub (32bit)\plugins32\MSUColorEnhancement.vdf'': The specified module could not be found''
I tried to VirtualDub 64 bit with the same result.
Any specific reason why ?
The "module" that "could not be found" is probably not MSUColorEnhancement.vdf itself, it is probably a support library such as the Visual C++ Runtime
[Attachment 43687 - Click to enlarge]
Which runtime version though, I have no idea. Here's the latest runtime download from Microsoft, you can try it.
MSUColorEnhancement loads fine for me BTW, using 64-bit Windows 8.1 and 32-bit VirtualDub or VdubFM.Last edited by raffriff42; 10th Nov 2017 at 21:05. Reason: links
Please do not call it a "codec", it is not used to save the video in a file in a specific format. As the extension suggests (VDF = "VirtualDub Filter"), it should be called a "filter".
It works for me:
But that VirtualDub filter doesn't appear to accept any arguments. All you will get is the default settings. Even in VirtualDub, when you use Save Processing Settings the filter's settings are not included in the .vdscript file (and therefore not loaded when you Load Processing Settings).Code:LoadVirtualDubPlugin("g:\Program files\VirtualDub\plugins\MSUColorEnhancement.vdf","MSUColor") ConvertToRGB32() MSUColor()
12th annual / 2017 MSU Codec Comparison results
By sophisticles in forum Latest Video NewsReplies: 0Last Post: 28th Aug 2017, 00:21 -
Lagarith lossless codec / Adobe Premiere color problem
By Woncler in forum EditingReplies: 3Last Post: 7th Jun 2015, 16:58 -
Feature request: Ignore list enhancement
By Selur in forum FeedbackReplies: 11Last Post: 9th Jul 2014, 13:07 -
Number plate video enhancement
By wanna catch em in forum Newbie / General discussionsReplies: 8Last Post: 16th Jun 2014, 09:56 -
Burglar image enhancement, any ideas please?
By amissonne in forum EditingReplies: 36Last Post: 22nd Jan 2013, 23:10
