Hi There,
I use TMPGenc for several months (almost a year) and I never had any problem with it (I was working with win98 SE). At least until I installed Windows XP.
The program still encodes to MPEG-1 with no problems, but when I try to use the MPEG Tools, I get an error (when I cut a movie and finish selecting the splitting point), apparently no harm is done, so I continue to split the movie.
When I play the file in the computer, the video and sound are in sync, but when I try the same movie in the Standalone DVD Player, the sound becomes out of sync.
I tried this with several movies and several setting, and always got the same problem.
Then I tried to use another mpeg cutter (iFilmEdit now called CinePlayer Editor), from this point on I never had any sync problems - the problem is that Cine Player Editor is not free and TMPGEnc is.
After all this my question is:
Are MPEG Tools included in TMPGEnc incompatible with Windows XP Pro?
Is yes, is there any patch for it?
Thank You
Pinho
I Have the same problem, hopefully there will be a fix for this....until then I will have to cut in Win2000.
Cheers
MPEG editing tools for the Mac
By HitTheRoad in forum MacReplies: 9Last Post: 7th Nov 2011, 16:43 -
what consumer/prosumer NLEs have good audio tools, and like mpeg-2+avchd
By mcbmcb0 in forum EditingReplies: 4Last Post: 3rd Dec 2010, 14:18 -
Daemon Tools Pro 10 gives Error code 6
By Benjy in forum ComputerReplies: 3Last Post: 30th Jul 2010, 00:01 -
DAEMON Tools Pro Standard - free today only
By aedipuss in forum Latest Video NewsReplies: 4Last Post: 23rd Jul 2010, 10:12 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
