Hello to all. When encoding in Megui a longer duration movie (2 hours+) the program is splitting the final encode into 2 separate files. It should be only one file after encoding but instead there are 2 separate files (one file with 2GB in size and second file around 400MB) Please is there a method to fix this? I was looking in megui settings but i cannot see it nowhere.
Thanks in advance
Details, details, details...
a) Do you encode to a file system which does not support huge files?
b) Do you encode to a container format which does not support huge files with the selected options?
c) Did you accidently select an option to split output files?
Answers for all these question should be found in your MeGUI log file. Did you post that here? -
Thanks LigH.de for your help, i figured it out another way, just joined the two files together with AviDemuxīs append function. And this happened only first time to me because the movie i was encoding had 2hours 48minutes, it did not happen with less duration movies, so its not a big problem now.
Hi,
there is in one click encoder in advaced config tab splitting on the bottom. Check if you haven't it on by mistake.
Bernix -
No doubt you have selected an option to split your encode into 2 gb parts. This option is there for OS that does not allow for files/format typically Fat32(IIRC) that will not allow for larger files.
There's two options when selecting AVI as the output and using AutoEncode & OneClick. "Standard" and "PC". I kind of remember the difference is "Standard" doesn't use OpenDML, so it's limited to 2GB. Or it could be a 1GB limit and I've got it wrong.
http://www.avi-io.com/2_4_gig_issue.htm
I haven't tested it or used AVI as the output for almost an eternity, but that's another possibility.
It'd be easier to provide an answer that's not guesswork if you provided more details.Last edited by hello_hello; 10th Nov 2017 at 10:55.
Video not exporting to separate files
By superskid in forum EditingReplies: 3Last Post: 1st Dec 2016, 15:18 -
AVerMedia RECentral and separate MP3 files...
By PureChaosX in forum Capturing and VCRReplies: 1Last Post: 9th Mar 2016, 17:57 -
Question about how TV digital recorder limits/splits file size to 4GB
By jimdagys in forum DVB / IPTVReplies: 3Last Post: 1st Jan 2016, 18:11 -
Converting Multiple Files Into Separate Files
By ashes17 in forum Video ConversionReplies: 1Last Post: 15th Aug 2013, 01:22 -
How to splice together separate 5.1 .wav audio files??
By JetrellFo69 in forum AudioReplies: 3Last Post: 23rd Dec 2012, 17:13
