Original source >>> MPC-HC displays resolution = 787x576
- General : B:\Berlin Alexanderplatz\01 серия.mkv
- Format : Matroska at 1 562 kb/s
- Length : 914 MiB for 1 h 21 min 47s 834 ms
- Video #0 : AVC at 923 kb/s
- Aspect : 720 x 576 (1.368) at 25.000 fps
- Audio #0 : AC-3 at 192 kb/s <<< RU
- Infos : 2 Kanäle, 48,0 kHz
- Audio #1 : AC-3 at 192 kb/s <<< RU
- Infos : 2 Kanäle, 44,1 kHz
- Audio #2 : AC-3 at 224 kb/s <<< DE
Toolnix muxed (RU-Audios removed) >>> MPC-HC displays resolution = 787x576
- General : B:\T-BAP [1980] Nr02 3A(-RU-RU+DE) 01-14 Die Strasse beginnt [720x576_81'26.720].mkv
- Format : Matroska at 1 183 kb/s
- Length : 689 MiB for 1 h 21 min 26s 720 ms
- Video #0 : AVC at 957 kb/s
- Audio #0 : AC-3 at 224 kb/s
Avidemux muxed (RU-Audios removed) >>> MPC-HC displays resolution = 720x576
- General : B:\A-BAP KLASSIFIZIERT\Nr02\BAP [1980] 3A(RU+RU+DE) 01-14 Die Strasse beginnt [720x576_81'26.760].mkv
- Format : Matroska at 1 185 kb/s
- Length : 690 MiB for 1 h 21 min 26s 760 ms
- Video #0 : AVC at 937 kb/s
Why MPC-HC displays "Avidemux muxed" resolution 720x576, and original video e "Toolnix muxed" resolution 787x576?
Additional question:
Why are "Format" and "Length" also changed (slightly) when comparing "Toolnix muxed" with "Avidemux muxed"?
Avidemux doesn't seem to retain any anamorphic aspect ratio when remuxing. It appears to be a bug.
The format/length difference may be because by default MKVToolNix saves statistic tags when muxing so MediaInfo shouldn't have to guess. That's the only logical reason I can think of for that one. What does MPC-HC say regarding the duration in the navigation bar? It uses MediaInfo to obtain some information. -
You can obtain ms durations from MPC-HC by right clicking on the status bar where the duration is displayed and selecting "high precision" (while a video is open). I'm not saying that'll guarantee it's always 100% accurate, but it'll display durations in hours, minutes, seconds and milliseconds.
Edited audio file loses volume when muxed. Avidemux being used.
By pooksahib in forum Video ConversionReplies: 5Last Post: 22nd May 2016, 23:45 -
Help: MKV file performed broken pixels after muxed by tsMuxeR
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 10Last Post: 28th Apr 2016, 15:16 -
Avidemux crashes when I open videos with subtitles muxed in them
By TheRandomOne in forum Video ConversionReplies: 4Last Post: 5th Jan 2016, 15:03 -
Adding intro in to an MKV with MKV toolnix
By Nozem013 in forum EditingReplies: 5Last Post: 26th Sep 2015, 14:44 -
Is there any easy way to add chapters to a muxed mkv?
By okizen in forum MacReplies: 7Last Post: 28th Jan 2014, 10:28
