hi.
in ASS subtitles, there is a font that I like, the bad thing is the spacing between two lines is a little bit big, I would like to reduce line spacing.
is there a way to do this? a tag or something?
I know, it will not help you. But there is possibility do it in Potplayer. Subtitles, subtitles style, and subtitle font style settings. And here is line spacing.
Otherwise the ass subtitles has not this possibility. Or you can modify your font in some font editor, Font forge possibly has this ability but I never tested it.
BernixLast edited by Bernix; 8th Nov 2017 at 18:36. Reason: correction of word
http://designwithfontforge.com/en-US/Line_Spacing.html
the problem with modifying fonts can lead to some problem. Don't know how is it with windows included fonts, but there are for sure fonts, that are copyrighted or similar.
Bernix -
https://www.md-subs.com/line-spacing-in-ssa is a good article on increasing or decreasing line spacing. Might give this a try.
Line Spacing in ASS/SSA
By Max Deryagin in forum SubtitleReplies: 19Last Post: 13th Aug 2023, 06:12 -
Vertical line spacing in ass subtitle file
By spopic in forum SubtitleReplies: 3Last Post: 21st Jun 2017, 03:07 -
How to reduce the graininess?
By bebetoalves in forum Video ConversionReplies: 1Last Post: 27th Mar 2017, 13:36 -
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 14:03 -
VLC Command Line - how to reduce FPS and keep speed
By mkvideo in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2013, 14:51
