hello,
If I capture using my Pinnacle Studio PCTV card/W98SE, above 352 x 240, I start getting images with jagged (I do not know how to put it, maybe distorted edges) moving objects. In fact, the edges of moving object are not smooth but sort of made of many fine lines.
Can anybody help.
Regards,
Roht
That is interlacing. You need to use a deinterlace filer in something like Vdub to remove it.
There is a good explination of interlacing at lukes video, just do a search.
Craig -
Thank you very much. Yes, it is in fact interlacing. I read Luke's articles as mentioned by you and now I know what it is. These jagged lines had been bothering me for many weeks and I had not really started to make VCDs as I did not know how to go around this problem.
Now it's clear.
Thanks once again.
Regards,
Rohit
Jagged lines upon playback
By seven_deuce offsuit in forum Video ConversionReplies: 10Last Post: 17th Jul 2010, 09:31 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
No jagged DV to HD possible?
By chamo in forum EditingReplies: 8Last Post: 22nd Dec 2008, 18:49 -
need to swap images in and out via button states in DVD Studio Pro 4
By theMonseignuer in forum Authoring (DVD)Replies: 2Last Post: 26th Jul 2008, 12:06 -
Removing Jagged Effect
By Vid-Kid in forum RestorationReplies: 5Last Post: 20th Jan 2008, 22:03
