Is there a good DVD Rip program to rip damaged DVD's I normally use Shrink or DVD Fab, but theyre both failing.....Thanks for any advice
	You could try IsoPuzzle.
 You should also wash the DVD to clean the surface. I use dish soap and a soft paper towel to dry.
 Any large scratches or gouges may be unreadable, but you may recover the rest.
 Some optical drives are better than others at reading problem discs.
 And you also need a decryption program for commercial discs.
 I have had to hand polish a few DVDs to smooth out scratches.
 Some CD stores may have polishers and charge a nominal fee for the service.
  ☣ DVD laser demolished by damaged Audio CD? ♦ Technology MayhemBy TechLord in forum Newbie / General discussionsReplies: 7Last Post: 1st Apr 2019, 15:02
  Repairing damaged DVD files with hex languageBy dvdmaster1 in forum Newbie / General discussionsReplies: 25Last Post: 9th Oct 2017, 12:06
  recovering a damaged DVD movieBy JohnnyBob in forum DVD RippingReplies: 19Last Post: 18th Apr 2016, 11:52
  Damaged DVD DiscBy efiste2 in forum DVD RippingReplies: 6Last Post: 12th Dec 2014, 09:53
  Damaged DVDs not rippingBy hollowman in forum DVD RippingReplies: 20Last Post: 11th Nov 2013, 22:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
