Hi guys, after a longer time i wanted to encode a movie like always, (i have new pc so i had to download a new version of Megui) i turned it on and wanted to choose my setting in the Encoder settings area. Im looking for "Aften AC3" in the audio settings and "Xvid 2pass Balanced" in the video settings. But it seems missing from Megui! Now i dont know if this is normal or something changed in Megui? Can someone help me? Thanks
Check if your MeGUI update server is set to "development" instead of "stable". It's quite recommendable, MeGUI is updated frequently with new features, but stable versions don't appear often.
After finishing an update, call the updater again manually (Ctrl+U) and check if any tools related to Audio presets, ffmpeg, and Xvid (encoder and presets) are possibly disabled, but offer updates after enabling them again (via right-click).
Aften may be rather obsolete as AC3 encoder, quality-wise, since ffmpeg offers a superior one. MeGUI may only offer an "FFmpeg AC-3: *scratchpad*" template, though, so you will have to set up your own codec preferences and save it as your own new audio preset. -
LigH.de thank you for your help , i switched to development server and updated everything manually but unfortunately it does not work, its still the same. Any ideas?
Hi,
it sounds new computer 64-bit version of Megui. They noted that you can select xvid but it will not work. Try 32 bit version.
Can't find predefined preset.
"Added support for Xvid 1.3. An additional automated step is required as the output file must be prepared with FFmpeg."
Or try older version
BernixLast edited by Bernix; 6th Nov 2017 at 09:22.
Hi Bernix, i works! I tried an older version and its the same like i had on my old computer, thanks.
Aften was removed for AC3 encoding ages ago. MeGUI encodes AC3 with ffmpeg now (Aften was integrated into ffmpeg, then abandoned).
I'm not sure about the Xvid preset. I've already deleted them from MeGUI myself, but the old Xvid profiles were still in MegUI's update cache folder so they're attached.
Or open MeGUI's updater, scroll down to " Xvid profiles" at the bottom of the list, right click and force a re-install to see if that works. The profiles mightn't be downloaded by default.Last edited by hello_hello; 8th Nov 2017 at 13:19.
Presets are no miracle. Understanding the encoder options is a much safer method to produce acceptable results reliably.
Megui settings for anime?
By qnkov in forum Video ConversionReplies: 4Last Post: 17th Apr 2017, 08:28 -
Best Megui settings for anime?
By qnkov in forum Video ConversionReplies: 3Last Post: 3rd Apr 2015, 03:26 -
MEGUI + x264 settings
By Cunhambebe in forum Video ConversionReplies: 41Last Post: 18th Apr 2014, 06:14 -
I want the best settings for MeGUI
By mmkk in forum Video ConversionReplies: 19Last Post: 9th Mar 2014, 05:36 -
use besweet encoder in megui as audio encoder
By dani010 in forum AudioReplies: 3Last Post: 25th Apr 2013, 09:10
