Hi friends! When transferring VHS, VHS-C and Video8/Hi8 I use one of my two Canopus ADVC-300 as TBC and FireWire interface for my computers. When there are noise between two clips on a tape, the connection between the ADVC-300 and my computers gets lost and I need to restart the ADVC and Scenalyzer. It doesn't matter if I run the ADVC in PC or Unit mode. This happen with both ADVC's and with different computers. Instead I can use a Panasonic DMR ES10 passthrough as TBC and my Sony DSR11 as a passthrough converter to Firewire. That works flawless. I can't imagine that the ADVC-300 was ment to have this limitation...
I have googled these problems but can't find anything explaining how to fix or make a workaround to these problems.
Any ideas?
Results 1 to 9 of 9
I have an ADVC300.
let me guess...yes you tried with two different ADVC-300 and two different computers. BUT DID YOU TRY WITH A DIFFERENT FIREWIRE LEAD?
Ive always had massive problems with firewire leads and my ADVC300..it just hates some, kinda sometimes likes others and theres only a few it really works with properly... -
Hi Blackout, thanks for your reply! Yes I have tried different leads, both 4 and 6-pin. I use these leads with other equipment and they work flawless. I recognize the solution that you suggest from other FW-devices I’ve had in the past where only one FW-lead works but not others, not even new ones. My Sony DSR-11 MiniDV-recorder/player can be used as a passthrough A/D-converter but it lacks the TBC-function. On the rear of that device there is a switch that - if enabled - will automatically rewind and restart the tape AND also stop the capturing process if there are an unrecorded (noisy/scrambled) part between two film sequences. Luckily the switch for disabling that feature is there and that makes me wonder if this is attributable to the same cause and there might be a ”fix” for the ADVC-300 as well.
Best Regards
Sven -
I hope you were trying with different power supplies as well????? I often find that power supplies still continue to feed 12 volts but they lose amperage...and in the case of eg Hard drive docks the unit will work until its "under stress" and then it will drop off the PC....maybe this is happening?
I understand the problem being described. And I suggested working around the problem by using the Panasonic DMR ES10 as his pass-through TBC. If it's the cable causing the problem or something else, yes, he can keep trying to diagnose it with your help. Me, I wouldn't worry about it since he already has a workaround solution.
As for cables, I have 4 pins into the ADVC-300 and 6 pins into the Firewire card. It's been awhile, but I think I remember reading to get a Firewire card with a TI chipset. So I did. Maybe you know more about that than I. -
youre right about the TI Chipset as well mano. Without it things go haywire and the ADVC drops off the firewire often. That could very well be his problem also.
Canopus ADVC 300 Firmware Request
By JRivera in forum Capturing and VCRReplies: 12Last Post: 21st Sep 2025, 05:27 -
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 12:19 -
Canopus ADVC-300 and other TBCs to die for
By Leo E. Backman in forum RestorationReplies: 22Last Post: 4th Apr 2017, 14:41 -
BMD Intensity Pro 4K, I-O Data GV-USB2, Canopus ADVC-300 Shootout
By SameSelf in forum Capturing and VCRReplies: 4Last Post: 4th Oct 2016, 09:43 -
advc 300
By devdev in forum Video ConversionReplies: 8Last Post: 27th Dec 2012, 08:06
