Results 1 to 20 of 20
    Nov 2017
    Title says all. Basically if I try to convert a 60fps video using NVENC the application crashes, but if I scale down the framerate to let's say 29.97 or disable NVENC, it works. If it helps, here's a sample video I uploaded for others to reproduce the issue:
    http://www13.zippyshare.com/v/BT4yyeyd/file.html
    Nov 2017
    Anyone?
    Dec 2012
    Germany
    maybe try version 3358? people had crash issues with newer ones
    Nov 2017
    Nope, no dice. :/
    Nov 2017
    Any ideas?
  6. what the GPU? 1050 GTX?
    What version video drivers? 385.69?
    Nov 2017
    Yup, I'm using a GTX 1050, and as for the drivers, the one currently installed is 388.00.
  8. Can you post event crash log of Xmedia Recode, maybe from this can see what's the problem
    tutorial event logs when a program crashes:
    https://www.cyberlink.com/support/faq-content.do?id=10449
  9. Member Bernix's Avatar
    Apr 2016
    Europe
    You can try of course different program to encode with nvenc 264. I just try it in different program, no problem nor with nvenc Hevc. Tested in avidemux. If the question is just why software crashed, dont know. I have 1050ti with 4gb, 1050 has only 2gb, therefore I suggesting to use different software.
    But the bitrate of original file is 738 kb/s for video at 60000/1001 with resolution 1280x720. You can't get similar bitrate with nvenc at reasonable quality. IMHO Even reencoded with cpu will affect picture quality at this bitrate.
    EDIT: the video is full of duplicates and original file is 25 fps. Just for the record.
    Bernix
    Nov 2017
    Bernix
    Care to vouch for a decent GPU transcoder or two?
  11. Member Bernix's Avatar
    Apr 2016
    Europe
    Sorry, don't understand if is it phrase. Nvenc supports two codec h264 and HEVC -> h265. Second is more powerful but of course more demanding, both should be supported by your card. The problem with hevc is smallest support of HW players. Not problem playing on PC.
    Bernix
    Nov 2017
    Bernix
    Sorry about that. What I meant was if you know of a better application that uses NVENC besides xmedia. I've tried shareware/retail tools like DVDFab before, but while they do a half-decent job they seem to be of shady nature.
  13. Member Bernix's Avatar
    Apr 2016
    Europe
    Avidemux, as I mentioned. It is easy to handle. Straight forward program.
    Bernix
    Nov 2017
    Bernix
    Anything else besides that?
  15. Member Bernix's Avatar
    Apr 2016
    Europe
    For example this
    You are on win 10 so shouldn't be a problem. But there is some negative reaction as well. But ratting 8/10 looks good.
    Bernix
    Nov 2017
    For example this
    Bernix
    Might as well give that thing a try then, thanks!
    Nov 2017
    One thing though, A's Video Converter also fails regardless of whether I use NVENC or not. Can anyone walk me through this?
  18. Member
    Nov 2017
    Alright, here's the Event Viewer log you requested:
    Faulting application name: XMedia Recode.exe, version: 3.3.7.8, time stamp: 0x59f236c0
    Faulting module name: XMedia Recode.exe, version: 3.3.7.8, time stamp: 0x59f236c0
    Exception code: 0xc0000409
    Fault offset: 0x0023929c
    Faulting process ID: 0x6f0
    Faulting application start time: 0x01d35cf5fa8281b9
    Faulting application path: C:\Program Files (x86)\XMedia Recode\XMedia Recode.exe
    Faulting module path: C:\Program Files (x86)\XMedia Recode\XMedia Recode.exe
    Report ID: dd94e6a7-6602-402b-9a95-3f4cc49ac41d
    Faulting package full name:
  19. Originally Posted by huckleberrypie View Post
    I don't see anything
    that can solve crashes
    Nov 2017
    Well that's what I got upon following the guide you linked earlier. :P
