Hello everyone.
I am a new member.
I have windows 10 to 64 bit, a Gefroce 970 GTX video card, and Mediacoder: version 0.8.49 build 5890 (Premium).
I was going to change the video card, with a 1000 series (Pascal).
Because, my video card is not able to use NVENC and encode to "main10" and 10 bit color.
I wanted to know if with a 1000 series. I could make encoding from UHD source via NVENC, without any problem.
Using the "Main 10" profile, 10 bit colours and also having the ability to keep HDR instructions.
I have read that the 1060 GTX video card has a lower CUDA CORE, but a higher clock than the 970 GTX.
Which of the two parameters is most important to make the rip more quickly?
Thank you.
The 970 will encode using NVENC. XMediaRecode and Simple x264/x265 will do this.
Yes, I know that "x265" allows it to do.
But, I want to do some tests with "NVENC" to speed up coding times.
My video card (geforce 970 gtx) does not support HEVC (with nvenc) encodings, with "main 10" profile and 10 bit color (which are used for UHD sources).
But only with "Main" profile and 8 bit color! With the result of having "no good", colors.
To make encodings with NVENC and the "main 10" profile and 10 bit color. I should buy a new video card ("1000" pascal series).
I wanted to know if it was possible to save the HDR instructions and the 10 bit color, via an AVISYNTH script. Without having to buy a new video card!
Thank you. -
Hi everyone.
For coding through NVENC in "HEVC Main10 10 bit", should I buy a GEFORCE 1000 series (Pascal), video card?
If I wanted to keep HDR coding instructions, with MEDIACODER, how can I do it?
To keep HDR (SMPTE ST 2084) instructions with coding, i only need to purchase a GEFORCE 1000 series, or do you not allow the program?
Thank you.
UHD BD Specs
By SameSelf in forum Newbie / General discussionsReplies: 18Last Post: 4th Jan 2017, 16:59 -
Sony on UHD
By SameSelf in forum Latest Video NewsReplies: 1Last Post: 1st May 2016, 01:48 -
nvenc hevc
By madhatr in forum Video ConversionReplies: 4Last Post: 19th Dec 2015, 19:07 -
nvenc compatibility
By amrel in forum Video ConversionReplies: 0Last Post: 29th Nov 2015, 11:02 -
UHD TV shopping
By RKF in forum DVB / IPTVReplies: 24Last Post: 10th Aug 2014, 21:09
