Hi all,
I really know very little about audio panning. But I've come across an issue with 2 VHS tapes. The vast majority sound fine - but these two tapes the audio when captured the same way is not as loud and sounds like it is missing all bass. I demuxed the audio and played around with it in audacity and found that it sounded much better if I panned the audio to the left or to the right. Could anyone help explain what is happening and the best fix? Thanks!
Samples attached.
That worked. Thank you for the tips and correct terminology! This is not a problem with my overall setup - must be something about production on this tape set (both tapes part of the same set).
.AVI and .MP4 video - can I mix
By Mike_EH in forum Newbie / General discussionsReplies: 8Last Post: 18th Oct 2015, 15:53 -
low bass in mp4
By shun in forum AudioReplies: 6Last Post: 9th Jul 2013, 20:42 -
Reduce Bass in BD rips
By Mattevansc3 in forum AudioReplies: 12Last Post: 28th May 2013, 16:04 -
I want to mix 7.1 music for BD Audio, where do I start?
By shadyJ in forum AudioReplies: 3Last Post: 5th Apr 2013, 19:00 -
Help with bass Configuration in AC3 filter
By thinredline in forum Software PlayingReplies: 1Last Post: 27th Feb 2013, 05:39
