Hi!
I use DVD2SVCD 1.0.8 (b1) and Cinema Craft Encoder 2.5 SP to convert DVD in S-VCD PAL. I would like to use a Multi-Pass VBR mode, but while encoding, CCE says me: "The pictures you are trying to encode are not the same of the previous pass". Why? I have not changed any setting, and CCE says this with any movie. My CPU isn't overcloacked.
Another thing.
I need to fit Evolution, a 97Min. movie on 2 90Min. CD-R. So, I need to use VBR. What bitrate values can I use to fit 7 addictional minutes on the CD-R?
Thanks 4 yours helps!
Daniele Esposito.
Have you read the DVD2SVCD documentation? This is such a common problem that it was put in the FAQ.
Read question #27 here http://forum.doom9.org/showthread.php?s=&threadid=21859
and #34 if it applies to you.
If your movie is 97 mins and you have an additional 7 mins then you have a total of 104 mins. Download a bitrate calculator from the tools section and calculate what bitrate to use to fit 104 mins onto two 90 min cdrs. This is all covered in the guides.
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 15:23 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 14th Jul 2007, 23:24
