Comparing a BD50 untouched at 37Mbps vs Ultra HD re-encode at 26Mbps. Curious as to which should provide a better picture when viewed on an HD (1920x1080) monitor/TV assuming the re-encode is of high quality.
Results 1 to 9 of 9
I'm not implying the UHD is generated from the BD50. The UHD transcode would be from a full resolution UHD original source disk.
I ask the question simply based on the fact that, during the early days of HD, it was prized to have a DVD transcoded from an HD disk original source due to the belief it offered a superior image - even at a DVD standards bitrate. -
Yes, so in theory it should be the same as well. But who knows, if that bitrate is enough. 26Mbits is quite reasonable. If it was done by someone who knew what he was exactly doing, I'd says yes. Also that UHD, was it really UHD or just upscale, perhaps not, just reasoning.
lossless is always better than lossy.. rather uncompressed is always better than lossy..
Something is always lost in the compression.. (Compare scenes with high action or dark scenes) -
Yes UHD could be just upscaled reencodes.. no new info added to the original resolution..
Appreciate the replies!
As for "Also that UHD, was it really UHD or just upscale, perhaps not, just reasoning.", that gave me something to think about. I do understand it's possible much of the UHD content available from streaming sites could very well be upconverted but what is the likelihood of UHD retail disks also falling into that category? -
UHD sell thru exclusivity for now, it just starts, so sources are very likely to be some sort of "above" fullHD.
How much "above" that is a question, it could be 2k, perhaps 4:2:2 and upscaled so it is sort of ok to upscale to 4k 4:2:0. New movies might be shot 4k, but CGI could be only 2k, so I don't know how they bring it together, there is a huge difference to compute 2k as oppose 4k. Nature, documentaries perhaps 4k, or mixed footage depending on what environment it was shot. -
Check this site it should help you decide what is real or not, http://realorfake4k.com/
BD50 to BD25 best quality?
By PatrickBatman in forum Blu-ray RippingReplies: 26Last Post: 2nd Oct 2020, 16:06 -
WebMux 2160p vs Untouched 1080p
By Sgt Hartman in forum Blu-ray RippingReplies: 2Last Post: 11th Oct 2017, 20:37 -
BD50-to-BD50 copy isn't playing
By Tyrexionibus in forum Blu-ray RippingReplies: 15Last Post: 23rd Dec 2015, 09:37 -
How to shrink 3D BD50 to BD25
By danswano in forum Authoring (Blu-ray)Replies: 20Last Post: 23rd Oct 2013, 08:19 -
Using HdBrStreamExtractor v0.8 what AUDiO option keeps it untouched?
By botdvd in forum Newbie / General discussionsReplies: 13Last Post: 28th Jul 2013, 22:33
