Hi,
I backup my blurays to smaller file size.
But som blurays are very grainy?!
I know that removing grain will also remove some quality, but i prefer smooth video, so my question is:
What software is the "best" to remove grain or smoothen out the video, while re-encoding the file?
I normally use Handbrake to encode my blurays, but the denoise functions are limited, at least at my experinces 🙂
Hi,
do you know, you can use --nr=X where X stands for number, you should tested. There should be some reasonable settings, If I were you I start on small portion of video using 400 and above. It is not best, but is superfast motion compensated filter, that can reuse data from encoding the video (x264).
Good article about it
Bernix
Help on how to get rid of the grain/noise.
By ricardouk in forum RestorationReplies: 11Last Post: 2nd Oct 2016, 19:45 -
Recommended VirtualDub (Or Avisynth?) Plugin(s)-Filter(s) To Remove Grain
By LouieChuckyMerry in forum RestorationReplies: 14Last Post: 7th Oct 2015, 00:21 -
By LouieChuckyMerry in forum RestorationReplies: 2Last Post: 27th Oct 2013, 23:57 -
Noise/Grain
By x264 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2013, 08:29 -
how to remove grain without loosing min details
By baunduley in forum RestorationReplies: 27Last Post: 6th Feb 2013, 17:41
